pushrod length
Old Apr 25, 2009 | 11:07 AM
00 black ss's Avatar
Default pushrod length
i want to order the ms3 cam package today from tsp with the prc .660 spring kit. what size pushrods do i need with stock 853 heads? thanks in advance.
Old Apr 25, 2009 | 05:16 PM
does anybody know? really would like to order this tonight
Old Apr 25, 2009 | 05:37 PM
Notmyvette's Avatar
Not to up on these motors much but should be the same for any motor....it depends on a bunch of things, deck height...if the heads or deck have been cut before, head gasket thickness, etc.....Correct way to find out is use an adjustable pushrod, and then order the right size from there...Asking what other people use will just get you in the ballpark
Old Apr 25, 2009 | 06:23 PM
i would use a pushrod checker if i was doing it myself but im having my local tuner do the build. it should be the same length for all ms3 ls1's correct?
Old Apr 25, 2009 | 09:09 PM
67rsss's Avatar
Touchy topic right now. A lot of discusion as to what pre-load to run for safe, queit operation, as well as some variance between what the math shows, and what real measurement shows on guessing. Most likely, since you are shrinking your base circle, you will want longer pushrods. I would imagine most people advising between 7.4 and 7.45, though i cannot tell you which would be best.
Old Apr 25, 2009 | 09:37 PM
rice4eatingnotdrivin's Avatar
i have a comp cams SI5 cam and i use 7.4... but to be on the safe side i would just call texas speed and ask them
