need some help lifter is f*#ck take a look
The story line is a 99 firebird witha g5x3 cam only car. My wife was just cruising when it starting ticking. I towed it home and see the rocker arm is got lots of play like a collapsed lifter. I pull the head tonight and find the lifter is screwed. Half the roller tip is missing! I pull the lifter next to it and both cam lobes look the same. I do need to rotate the engine and see if the entire cam lobe is ok. I guess I'm looking for scaring on the cam? I will also pull the valley cover and see if I can find the rest of the lifter roller. Take a look at the pic below. Engine has 100k and cam swap m,aybe 10K Car has always had mobil 1 and very well maintaned. It ran for about 10 minutes before she called me and turned it of. If I have to pull this motor its gone and I will never work on a 4th gen again this engine bay sucks!!
ls1 or ls7 lifter ?
look at the lobe where you took the lifter out off. if the cam has discoloration (sort of like a rainbow) or the cam lobe has deep score marks you would have to get a new cam.
if it was me i would not start putting the motor back until you have found the other piece of the lifter.
and don't worry about the 4 jen engine bay, you will get used to it. it is a small price to pay for having the engine in the proper place.
I bought the car from a friend. Rapid motorsports did the cam swap/tune 4 years ago.
The cam lobe looks a little less shiny when compared to the lobe next to it. I thnk the cam is junk.
I guess I will drain the oil and pull the valley cover and see if I can find it.
I hope the cam has some numbers on it so I can replace it with same model g5x3 cam since there is a few variations of it.
ls1 or ls7 lifter ?
Last but not least...if the lifter looks like that, chances are it spun inside the block which means the lifter cup could be damaged as well as you need the lifter bores bored for either larger lifters or bushings installed to reuse stock style lifters. Do not go through with assembly with you taking a bore gauge and taking several measurements at diff loc's in the lifter bores to ensure roundness. Lifter trays are ~20 bucks. Machine work though is a different story.
The valley cover wont let you see the lifters like a gen 1 SBC/BBC...they're under the heads like V6 Bird said.
To me the way that lifter looks, it was ran for a little while after it started making noise (hence that roller chewed through) and im sure the cam is now a cool looking paper weight.
From past reviews the most likely scenarios are:
1- Bad cam (softer than needed lobes) Comp cam and Cammotion had issues before.
2- Lifter twisted in the holding cups (common issue with nasty results), change your cups.
3- Lifter collapsing,
![Wink](https://ls1tech.com/forums/images/icons/icon12.gif)
If you've ever seen an LS7 lifter you'd know that the lifter in the pics is not one. Its very distinct in the fact it has a larger bearing surface. So large it makes it easy to identify. And to post up about the pic of that lifter and the cam not being fucked up...is another internet mechanic. You know damn well the cam is FUCKED!
I can hear it now......
officer all I remember is catching a quick glimmer from the streetlight reflecting off the shiny metallic object in the dark night as the object tumbled through the still night air. Right before the object struck my forehead I distinctly recall seeing a larger bearing surface thus leading me to know that I had been taken down by the elusive LS7 lifter bandit....
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Actually, the fully skirted body is much more noticable. Not how exposed the LS1 lifter is. I also agree that the cam needs to come out. You really will want to have it inspected, but it is most likely toast.
you got to be ******* kidding me man. you are making a big deal out of nothing. i never stated that it is an ls1 lifter or an ls7, i was just asking if it was or not. instead of telling me that, yea this is not an ls7 lifter because it is not fully skirted or whatever, you come out like an *******, i could understand it i was stating that it was an ls7 lifter and pointing the guy in the wrong direction, but i haven't all i did was ask a ******* question.
dude everyone needs to calm down, looks like some internet tough guys. You can always tell who the little man syndrome typers are. I never said the lifter was a ls7 and I pulled the head to get the lifter out so I think I figured that part out. The cam is toast I was just hoping it would be ok. I drained the oil and found the rest of the lifter tip. My plan is to replace the trays with ls2 trays check the lifter bore and replace cam/lifters.
I hope that lifter bore is ok
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
I have a Camshaft out of a 2006 LS2 GTO. I also have a TSP MS3 but I had a lifter collapse on it also. Wasnt near as bad as yours my pushrod just went through the top so Im pretty sure the cam is still good but I havent got it checked out yet. Let me know if you want it. $200 + Shipping
