ptv clearance
Old Apr 28, 2009 | 12:46 AM
454navyss's Avatar
Default ptv clearance
im putting a tr224 cam in my 5.3 with a set of 706 heads, i want to mill my heads .030. will i have a problem with ptv clearance? any recommendations for pushrod length so i can at least drive it until i measure and buy the correct length, its my DD? thanks
Old Apr 28, 2009 | 06:23 AM
SweetS10V8's Avatar
You always have to measure PTV yourself. There are no excuses after your engine kills itself.
Old Apr 28, 2009 | 09:10 AM
bigboykilroy's Avatar
+ 1 .........Why do people insist on asking this when they know the answer?
Old Apr 28, 2009 | 03:08 PM
454navyss's Avatar
ok thanks for not helping
Old Apr 28, 2009 | 06:55 PM
Ramairbird's Avatar
You can't just guess on a pushrod length, and you can't ball park it till you have time to check it. This is an important measurement that if work by enough will break things. As far as the PTV again to know for sure you need to check it, what is the lsa of the cam? There re many variables that effect this including headgasket, cam specs, valves, etc. People want to help on this forum but there are things that you can't get a quick answer for. If people didn't want to help you they wouldn't take the time to type all this and tell you that you need to check these things. The only shot you have is if someone did a build like you have and they did all the checking, then it might be close.
Old Apr 28, 2009 | 07:41 PM
SweetS10V8's Avatar
I answered the ONLY part of your question that is critical in any way. Your welcome you ingrate.
Incorrect, hyd lifters have about .200" of plunger travel. 7.400" pushrods will work on 99% of cars on this forum that have stock rockers and lifters. They may not be 100% optimal, but they will work just fine without any issue.
