Headswap question
Old Apr 29, 2009 | 07:21 PM
05 GSXR 1XXX's Avatar
Default Headswap question
Have some heads going on my z28 this weekend, wondering if i should clean the carbon off the pistons while i have the heads off..
car has 107k miles
Clean them or not to clean them?
Old Apr 29, 2009 | 08:04 PM
vsocks1's Avatar
I would definately clean them....I assume they will be real dirty!!
Here is how mine looked with only 10,000 miles...
And here they are cleaned up!
Old Apr 29, 2009 | 08:55 PM
GTOFan350's Avatar
What did you use to clean them vsocks?
Old Apr 29, 2009 | 09:49 PM
vsocks1's Avatar
I left the old lifters & trays in until after the cleaning, plus stuffed rags in the lifter trays. I did each cylinder one at a time at TDC. I used denatured alchohol with non metallic scotchbrite pads and scrubbed my butt off. It will take you 4-6 hours to do it right....don't get discouraged...take a break and come back at it! After you are done....do it again and wipe each cylinder with a clean rag as you rotate the engine to remove any loose debris. When all is clean take a rag with fresh oil and wipe down cylinder walls.
Old Apr 29, 2009 | 10:01 PM
67rsss's Avatar
Wow, about two threads down we just answered the same question...
https://ls1tech.com/forums/generatio...f-pistons.html
Old Apr 29, 2009 | 10:29 PM
no he asked what to clean with, i just want to know how many people rec cleaning them while havin the heads off.
Old Apr 30, 2009 | 09:26 AM
67rsss's Avatar
I can't imagine being in there and not cleaning up the carbon deposits. I would highly reccomend you clean everything really well. Also, make absolutley certain that you clean out the bolt holes really well. Get EVERYTHING out of them, it takes a while, but if you don't, you are buying a new block real soon. Are you going with the ARP bolts or a new set of stockers? We used stock bolts, but I will tell you that getting the final torque angles is not terribly fun.
Remember too that that carbon build up can cause hot spots and pre-ignition...
Old Apr 30, 2009 | 05:11 PM
stock gm bolts.
bump
Old Apr 30, 2009 | 05:37 PM
01FbTaWs6's Avatar
i would def. recommend arp head bolts bro, so much nicer and easier!
Old Apr 30, 2009 | 09:04 PM
67rsss's Avatar
Originally Posted by 05 GSXR 1XXX
stock gm bolts.
bump
I agree with teh stockers. Unless you plan to pull heads a few times, the cost of the ARP's is prohibitive. Just take your time and ensure you get the bolts tightened correctly...
