cam 114+4 what does that mean?
Old May 2, 2009 | 12:02 PM
mike13's Avatar
Default cam 114+4 what does that mean?
Sorry if it's a stupid question but cam specs other than basic lift, duration is way over my head.
221/221 561/561 114+4
what kind of idle and powerband would this cam have on a stock LS1?
Thanks for the help.
Old May 2, 2009 | 12:34 PM
5.3LJimmy's Avatar
114 is the lobe separation angle(LSA) and +4 means there is 4 degrees of advance ground into the cam. The wider the LSA the less valve overlap you have. The idle will be smooth with a slightly noticeable lope and it will have a broad smooth powerband(1500-6500RPM).
Old May 2, 2009 | 02:57 PM
mike13's Avatar
sounds like a good cam for forced induction, do you think it will work with LS6 yellow springs?
Old May 2, 2009 | 07:26 PM
SOMbitch's Avatar
I don't remember LS6 spring specs but I think you are pushing it. Look at some PAC 1218's
