cometic gaskets????
Old May 3, 2009 | 11:46 AM
1320 killer's Avatar
Default cometic gaskets????
I recently pulled hte heads of my car. I have some Cometic gaskets and there was no leaks. I want to re-use them. What is the procedure for cleaning them up. I heard you have to use a copper spray. Thanks for all the help.
Old May 3, 2009 | 02:00 PM
wht97ws6ta's Avatar
Just clean them in mineral spirits. If you dont have that then starting fluid will be fine. And get you some K&W coppercoat in the aerosol cans and coat them good before you put them back on. Just let it set on the gasket for a minute or two and let it get tacky before putting them on.
Old May 3, 2009 | 05:32 PM
Thanks. i will probly be doing this over the weekend as soon as I get my heads back from the shop.
