Someone pleeeease help
Old May 5, 2009 | 09:18 PM
the jester 812's Avatar
Default Someone pleeeease help
ok i am freaking out, i just installed my new PRC 2.5 5.3 heads and a custom cam. the cam is a 232 236 with 648 lift. i talked to TSP twice and both times they told me that the PTV clearance would be fine. the heads were milled to 58cc's. it sounds like it might be coming from the front. im hoping that its the timing chain. but my friend who help put everything together thinks its the rockers.
it has perfect oil pressure, and runs fine except of course being the first start up after heads cam swap. i guess now i have to try to get thru tomorrow worrying about my car all day.
Old May 5, 2009 | 09:27 PM
tatasta's Avatar
I'm not a great cam guy but I am sure that those who are will ask you for the rest of the specs of your cam. Lift alone does not indicate PTV problems.
Good luck. Hope you are safe!!
Old May 5, 2009 | 09:35 PM
232/236@.050 Lift: .643/.646 110lsa, 109icl these are the exact specs
Old May 6, 2009 | 06:00 PM
someone ....anyone?
Old May 6, 2009 | 08:54 PM
thebulgd's Avatar
is there some kind of question hidden in that? Engine is making noise? Try being a little more clear. Could be I have reading comprehension issues, but I'm thinking not so much in this case.
Old May 6, 2009 | 08:59 PM
jrpimp00's Avatar
????IM Lost??? is it ticking, hissing, popping, what?? A little more info please
Old May 6, 2009 | 09:34 PM
SweetS10V8's Avatar
Did you check PTV yourself? If not, its your fault, no excuses.
No one can always be right about PTV all the time, there are too many variables.
Old May 6, 2009 | 10:01 PM
LS1-NAVY's Avatar
+1 i would check it with clay best way to make sure
Old May 7, 2009 | 02:05 AM
Notmyvette's Avatar
+1 for checking the ptv clearance before firing it up....
Do a leakdown or minimum a compression test to help diagnose what cylinder etc and leakdown will tell you if you did love tap a valve what valve hit, intake or exhaust
another thing that needs to be accounted for, for ptv clearance is cam timing, you could have a small cam but if that valve opens or closes too early or late something can hit.
I would do a compression test and go from there...
Old May 7, 2009 | 07:42 PM
SOMbitch's Avatar
I don't think it will clear with that much milling. I was told to run a stock thickness HG with NO MILL to stay safe and I am slightly smaller also 109 ICL..
Old May 8, 2009 | 10:17 PM
i really dont think its anything to do with PTV, everybody who has heard it says it sounds like the lifters, it is clicking sound, and i took it just a couple hundred yards down the street turned around and came back today. it is down on power but i would think after doing that, if it was valves hitting pistons, i would have really F'd something up. i will do a compression check tomorrow, then if its not good start tearing this damn thing apart again. i geuss i wont be driving it anytime soon. damn it. thats what i get for wanting more power. just couldnt be happy with 427 whp, had to get new heads and cam ****
