Comp 850-16 lifter preload
My question is what is the proper preload for these Comp cams 850-16 OE replacement lifters?
Also I measured while the motor was on the stand at TDC. It had been sitting at TDC for about 2 weeks. Now that I think about it, will this sque the measurement being that the lifters might have bled down?
Looking for some different opinions
My experience with those 850-16 is preload from .060>.100 I run mine in that margin, I prefer closer to .080
https://ls1tech.com/forums/generatio...r-preload.html
Here is what Comp recommends but just seems to low?
.030-.040
http://www.compcams.com/Technical/In.../COMP4-116.pdf
