Help me Pick my cam
Old Jun 14, 2009 | 01:05 AM
mtuggle86's Avatar
Default Help me Pick my cam
Im going to be buying a cam soon and I need some help picking it out Im looking at the TR224 Tsp 224r and Tsp 228r with 112lsa.Emissions do not matter I live in mich and theres no testing My needs are
#1 My car is daily driven and I would like a very street friendly cam with a decent idle while and a good amount of lope
#2 Reliable I dont want to be changing valve springs every 15k miles
#3 Last I would like to get the most power out of it I can given my other needs with a strong mid range with a peak power no higher then 6500
Car is an 2001 Camaro with M6 and 3.73 gears in the back 60k miles im planing on keeping the stock heads
Mods are K&N Fipk, Stock Ported TB, jet-hot longtubes, jet-hot ORY, flowmaster catback with cutouts
Old Jun 14, 2009 | 02:36 AM
ramdaspadhye's Avatar
TR224 should fit your nicely, probably on 112 since you're lookin for the lope.
Old Jun 14, 2009 | 04:49 AM
corvet786c's Avatar
The cam I have is very streetable and has a lot of torque. Alot in the entire rpm range. Check it out.
http://www.vincihiperformance.com/CA...%20LS1%202.htm
Old Jun 14, 2009 | 07:24 AM
USArmyZ28's Avatar
Trex or MS4 should do you nicely, jk lol.
Have you considered the GMPP ASA Cam? It lopes really hard for a smaller cam, also alot of the members on here who use the cam have very positive things to say about it.
Old Jun 14, 2009 | 07:25 AM
dre2013's Avatar
id go 228r
Old Jun 14, 2009 | 09:13 AM
Zach79Z's Avatar
Had the ASA cam in my 98 and loved it. Loped hard and drove very well for a mail order tune. Id suggest that or the VRx3 from vengeance
Old Jun 14, 2009 | 10:27 AM
01ssreda4's Avatar
i would go 228 also.
Old Jun 14, 2009 | 11:08 AM
mtuggle86's Avatar
will the 228r be much harder on my valvetrain then the tr224?
Old Jun 14, 2009 | 11:30 AM
Zach79Z's Avatar
TR 224-112" - 224/224 .563/.563 112 LSA
vs
TSP 228r" 228/228 .588/.588 112 LSA
The 228 will be a little rougher prolly just because it is slightly larger but it'll give you more lope like you want
Old Jun 14, 2009 | 12:08 PM
mtuggle86's Avatar
I was reading gm high tech performance and they tested the stock rocker arms and there testing showed the stock rocker arms where really only good for a little past 550 lift without excessive wear to the valve guides and valve tips Can I go all the way up to 588 without this problem?
Old Jun 14, 2009 | 12:19 PM
PREDATOR-Z's Avatar
Don't believe everything you read in those mags. That article is marketing at its best.
Old Jun 14, 2009 | 12:23 PM
mtuggle86's Avatar
well I just like to make sure but your prob right
What kind of power can i expect from both these cams?
Old Jun 14, 2009 | 12:35 PM
This one should lope pretty good for ya and still have loads of torque...
218/224 .605/.581 on 108lsa bout 5 degrees of overlap
Old Jun 14, 2009 | 01:00 PM
Big Red Z28's Avatar
Just contact patrick G and have him give you the specs for a custom cam he only charges 25$ and gave my specs within a couple days. Just fill out the sheets, tell him exactly what you are looking for as far as driveability and give as much info about your car, the more info the better, He is a great to work with, worse case if you dont like his specs you're only out 25$ and can always go with another cam. However i think you wil be very happy with Patrick G and feel more comfortbale after wards knowing you got the cam for you and not a general cam that will work well.
Old Jun 14, 2009 | 01:29 PM
Zach79Z's Avatar
with your mods im guessing 370-380ish?
Old Jun 15, 2009 | 11:00 AM
Patrick G's Avatar
LS1 Tech Administrator
TR224 will give you everything you're looking for. It's a very proven cam and won't wipe out your valvesprings as quickly as some of the other cams you mentioned.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jun 15, 2009 | 04:57 PM
mtuggle86's Avatar
would you suggest patriot duals and titanium retainers or just the comp 918s and steel retainers?
and also double roller timing chain or HD ls2 timing chain?
Old Jun 15, 2009 | 05:54 PM
As far as your gains i can tell you my old setup was fairly close to yours i had qtp 1 3/4 with qtp y pipe and cats, 3" Borla exhaust no cut outs, K@n FIPK, stock ls6 intake with ported stock tb, SLP underdrive pulley, HP Tuned not myself, 17x9.5 wheels, 4.10 gears, stock rear and tranny with spec stage 3 clutch and steel flywheel.
My cam was comp cams part #54-426-11 222/224 .566/.568 112 LSA using comp cams pro magnum 1.75 rockers and 918 springs.
My results were 380 rwhp/ 351 rwtq using a mustang dyno.
Old Jun 16, 2009 | 03:40 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I completely disagree with this statement. The 224R & 228R camshaft are far from super-aggressive camshafts that wipe out valvesprings. Joseph currently has a set of 60k mile Comp 918s he pulled used out of his brothers car that still has decent pressure & STILL works with these lobes.
I have no doubt all three of these camshafts will have a great life when combined with any of PRC's spring kits, or the Comp 918 spring kits.
If you'd like we can provide you with engine dyno data from both the 224R & 228R camshafts. We're dyno testing a bunch of camshafts starting next week & we'll have data all the way down to 2k rpm for you guys to checkout!!
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jun 16, 2009 | 03:58 PM
PREDATOR-Z's Avatar
Jason
From another member's TR224 cam lift report I can see that intake lobe has a variance of 56.6 and exhaust 52, so yes they are much less agressive than XE-R at 49
LSA: (111.7)
Lift: (0.565/0.565)
Duration @ .006 and .050: (.006= 278.3/276.6 & .050= 224.7/224.6)
IVO: (.006= 29.1 BTDC & .050= 4.6 BTDC)
IVC: (.006= 69.2 ABDC & .050= 40.1 ABDC)
EVO: (.006= 71.6 BBDC & .050= 47.9 BBDC)
EVC: (.006= 25.0 ATDC & .050= 3.3 BTDC)
