More info on the new AFRs
Old Nov 2, 2003 | 12:05 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Default More info on the new AFRs
http://forums.corvetteforum.com/zerothread?id=683267
First of all, thanks to Tony of Air Flow Research for making the two hour drive over here in the rain.
The head he brought over was a prototype , based on the LS6 head. The port was filled in with epoxy and then reshaped.
The actual castings are still at the foundry.
The port has been radically altered in a way no porter could do. The floor of the intake port has been raised approx. .500" and turned on it's axis. The short turn is much taller. The vein in front of the valve guide boss is extended behind the boss to kill the dead space behind the boss. This all requires ADDING material, not removing it. I'm very impressed with what has been done to this head. The velocity has to be increased dramatically. I'll bet there is a night and day difference in seat of the pants feel. Torque will be up a bunch. Peak flow numbers are up, which will definately increase peak horsepower, but I'm guessing the midrange will be dramatic.
The decks are much thicker than stock. There's more material above the intake port to support large roller springs.
The larger chambered heads (76 CC) will actually be thicker. The intake, exhaust bolt holes, and rocker bosses will be relocated accordingly so that pushrod length and manifold alignment will remain the same.
The smaller chambered heads (66CC) will be milled .060" or so and have all the holes in the stock location.
These will definately outperform any ported head out there ( Including my own).
I'm definately in the loop and will forward any new info I have.
Pricing will be at a 3% discount from retail. That's the max allowable. I will also have them at a wholesale level for shops wanting to buy in small quantities
Old Nov 2, 2003 | 12:14 PM
Scalpel's Avatar
Man, these sound impressive!
Old Nov 2, 2003 | 12:55 PM
JF WS6's Avatar
Can't wait to see the results from these on a stock cube car and a LS6 or LSX intake.
Old Nov 2, 2003 | 02:14 PM
DaleMX's Avatar
J-Rod, when will you get a functioning set of these to horse around with and what will they be, 66cc W/CNC?
Old Nov 2, 2003 | 02:31 PM
Z06PSI's Avatar
These might be my new head choice.....
Old Nov 2, 2003 | 06:25 PM
HOTROD98Z's Avatar
Do you have any updated info when these will be available?
