oil pressure WTF??????
You should be getting ZERO oil pressure when you shut down the engine. How can an oil pump make pressure when it's not turning? If you indicate oil press after you shut the engine down, your gauge or sending unit is screwed up.
You need about 40 psi during hot idle, and somewhere close to about 55 psi at highway speeds [oil hot]
That said, I would probably worry if you were not pushing at least 20 psi at idle on the hottest of days, after abusing the crap out of your engine.
55psi while cruising on the highway? I never see that on a summer day! I am only at 1700 rpms...
Why not use autotap or something similiar to chekc it and see what the sensor is actually reading. This way you can see if the gauge really is messed up.
Tommy
I said, that it should read ZERO with the engine turned off! How the hell can he have oil pressure on an engine that is not running?
TaTommy says: "I'm not entirely sure what your definition of "need" is, but if you have 10 psi of oil pressure at idle, you are in no danger of ruining anything..."
When did I say all you need is 10 psi at idle? If he had 10 PSI at idle, he would be looking at a low oil pressure light.
This whole thread is a waist of time ....
I stated that 10psi is fine at idle as far as not damaging anything goes.
I know YOU said you NEED 40 psi at idle.
I also understand that the guy's problem is his gauge is "F"ed up because it should be reading zero when the engine is off, not 10psi.
OK, I'm going to bed!
Tommy
