PTV Clearance Questions....
Running a 1998 Trans Am, and looking at swapping in a pair of 806 heads that have been milled .035" I know that 806 heads came factory with a thinner headgasket due to a larger CC. The question is, how much a cam can be squeezed in without PTV issues. Obviously, I will check when I assemble the motor, but I would just as soon be pretty close on the first attempt if you know what I mean....
Cliff's: Safe lift/duration on 806's milled .035"
Well of course. I just wanna be close on the cam I try t fit.
