Will a 234/242 cam clear?
Old May 13, 2009 | 03:47 PM
Smoke_ur_5.0's Avatar
Default Will a 234/242 cam clear?
I have an old comp cam 234/242 112lsa (4 degrees advance built in) I should be able to slip this in with a stock 2000 LS1 without any piston/valve clearance issues right? It should be the same spec as g5x4 cam. Probably going to throw it in, just thought I would double check to make sure.
Old May 13, 2009 | 04:01 PM
Damian's Avatar
LSX Mechanic
HOLY **** MAN! Long time no post! How have you been?
Yes it will clear a stock engine just fine.
Old May 13, 2009 | 06:03 PM
yeah I took a MUCH needed break. Been around the last couple months lurkin, the cam is for the wifes car. She still loves the 4th gen WS6's. Alot has happened in the last few years.
Old May 13, 2009 | 06:13 PM
vsocks1's Avatar
I would measure that one to be sure. I had 232/236 .595/.578 113+3 and with TFS 215's milled to 60cc had .040 on intake at 11* ATDC....
Old May 13, 2009 | 11:31 PM
Damian's Avatar
LSX Mechanic
There is a big difference between stock heads, and your setup. An LG G5x2 will clear on stock heads all day long. I wouldn't even bother measuring, I've done a handful of them and never had any clearance issues. (On stock heads)
Old May 14, 2009 | 05:34 AM
vsocks1's Avatar
I know there is a difference with stock heads - just being cautious. He is talking about a cam he said had the specs of a G5X4.
Old May 14, 2009 | 06:09 AM
tanka5.7's Avatar
i had a 237/242 609 lift in a stocker no dramas
Old May 14, 2009 | 06:22 AM
BigKap94z's Avatar
G5X3 on 112 clears with stock heads but its alittle tight at around .070" on the intake.
Old May 14, 2009 | 09:17 AM
Damian's Avatar
LSX Mechanic
234/242 = G5x2
Old May 14, 2009 | 09:19 AM
BigKap94z's Avatar
234/242 = G5x2
X2 is a 232/240. XER/XE FWIW. The specs given are for X3.
Old May 14, 2009 | 09:44 AM
Chrome355z's Avatar
Old May 14, 2009 | 01:12 PM
moeZ28's Avatar
Yeah, this guy basicly has a G5X3 on a 112 LSA.
