What spark plugs in a 408?
Old May 14, 2009 | 12:05 AM
elzz49's Avatar
Default What spark plugs in a 408?
Wondering what plugs to go with in a 408. Not doing FI or Nitrous. I think Compression will be 10.5 or 11 to 1. Thanks!
Old May 14, 2009 | 04:17 AM
00MaroonZ28's Avatar
NGK TR55's are good.
Old May 14, 2009 | 08:52 PM
BriancWS6's Avatar
I suggest TR6s gapped@.045". Once you are making a decent amount of power over stock, it's time to go to a colder plug.
Old May 15, 2009 | 06:53 PM
xdanny510x's Avatar
im using tr55
Old May 16, 2009 | 11:38 AM
SS94S10's Avatar
TR6 for sure. Part number should be a 4177.
Old May 16, 2009 | 09:20 PM
DVS99TRANS's Avatar
I am installing my 408 and am going to use TR55s for now. I am going to reuse my MS3 and PRC heads for now. But when I go bigger than that I am jumping to TR6s then. You should be straight unless you have a monster set of heads and massive cam.
Old May 16, 2009 | 10:34 PM
RyanSws6's Avatar
I went with the TR6 in my new 408. I had the 55s in my 347. No big deal to put them in now.
Old May 17, 2009 | 01:12 AM
transAm-98's Avatar
I'm also running TR-6's but i'm running 12:1 compression in mine.I think with your setup TR-55's would be fine, but I doubt you'd be hurting anything running the 6's
