Scorpion rockers
Old May 16, 2009 | 03:32 AM
vrtch ss's Avatar
Question LS1 Scorpion Rockers
Anyone have/heard of any problems with the new updated Scorpion Rockers?
Old May 16, 2009 | 07:54 AM
7th Darkness's Avatar
Just got a set of 1.8's not to long ago... have yet to install them, but they look solid and have good craftsmanship.
Old May 16, 2009 | 11:41 AM
mtjoy's Avatar
I've had a set of 1.7's on my car for about 2 years and haven't had any issues. The only problem I had was that a few of them working making contact with the valve covers. I clearanced the areas that were making contact and it has been fine since.
Old May 16, 2009 | 11:46 AM
ZMONSTER!'s Avatar
did anyone notice if the motor seemed quieter after installing these?
Old May 16, 2009 | 06:14 PM
mtjoy's Avatar
I can't say I noticed a significant difference. I'm running dual springs though not sure there's much that can be done to quiet them down.
Old May 16, 2009 | 08:49 PM
blkbird's Avatar
I didnt know they came out with a revised version
Old May 16, 2009 | 11:41 PM
ZMONSTER!'s Avatar
The first version that came out had several cases of broken rockers, they were revised soon there after.
Old May 17, 2009 | 04:09 AM
05gto60's Avatar
i had scorpions, but got rid of them. i dont know what it was, but on 2 different sets from scorpion the trunnion bearings got tight on most of them (over 10 both times) usually 2 were fine, a couple were getting tough to turn, and the rest i couldnt do it by hand. they warrantied both sets, but i didnt want to try a 3rd set, so i sold them. went back to the stock rockers and never had a problem (changed out to rollers with the 402 though). scorpion looked at both sets and didnt know why it happened, they were the updated ones too.
Old May 17, 2009 | 06:51 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Going to aftermarket rockers is a wated expense. It has been shown to only hurt valvetrain stability because it put extra weight over the tip of the valves and doesn't yeild anything in return.
The only downside to the factory rocker arms is their needle bearings, which Harland Sharp can rebuild and make bullet proof.
You never hear of a factor rocker arm breaking, but read once a week about the aftermarket ones breaking.
If they are fine for the Z06 and ZR-1 vettes, they are good enough for your f-body.
Old May 17, 2009 | 03:52 PM
vrtch ss's Avatar
Thanks for the feedback,Just picked me up a set,cant wait to slap them on my build.
Old May 17, 2009 | 04:55 PM
vsocks1's Avatar
That may be true on stock heads. As you probably know the stock rockers will wear the bronze valve guides on many aftermarket heads. So....they are not always a wasted expense!
Old May 17, 2009 | 07:08 PM
UNDER PRESSURE MOD
Beleive what you what, but unless you're running a 0.700" lift cam, the valve guides aren't an issue.
Old May 18, 2009 | 02:15 AM
05gto60's Avatar
yup, and ill believe my torn up AFR guides after using stock rockers with a .600 lift cam
Old May 18, 2009 | 07:05 AM
vettenuts's Avatar
I spent hours trying to shim my stock rockers to get an acceptable geometry, in the end I gave up and went aftermarket. I found the wipe pattern to be wide and in some cases it was not in full contact, i.e, the contact patch was towards the front/back of the valve stem. I am now running the YT's and they set up with a very narrow wipe and seem to respond much better to height adjustments with shims. While I think the stock rockers are a nice light design, I couldn't get them to work so I felt comfortable installing them.
