1.8 Rockers
Old May 16, 2009 | 01:05 PM
philsblwnz28's Avatar
Smile 1.8 Rockers
So I have stock 853 heads and was thinking about putting 1.8 rockers on. Has anyone done this and if so did you gain anything? Also what rockers did you use? Thanks
Old May 16, 2009 | 02:19 PM
SweetS10V8's Avatar
What ones are you concidering? What cam and valve springs do you have? You need to make sure your not going to coil bind your springs if they are stock!
SLP makes 1.85s..
Comp makes Gold 1.82s, and 1.85 Pro Magnums.
Old May 16, 2009 | 03:43 PM
It's all stock valve train. Should I do springs, retainers, locks, and then some 1.8's? I really like the Pro Magnums
Old May 16, 2009 | 04:36 PM
teke184's Avatar
stock springs wont handle 1.8 rockers....so yeah...replace those.
figure with the added lift and small reduction in friction...about 10-15hp
Old May 16, 2009 | 07:21 PM
SweetS10V8's Avatar
I honestly would pick up the 1.75 set of Pro Mags, Ive seen them, more than once, pick up 15-20hp on the engine dyno.
Ive also seen the Ultra Golds pick up 12rwhp on a guys car I know. I havent seen anying in person with teh SLPs but they look like a stock body with a nice trunion. Im sure they work very well.
Old May 16, 2009 | 08:04 PM
NemeSS's Avatar
none of the above, a hot cam with stock rockers will make more power
will still need to upgrade springs anyway.
Old May 16, 2009 | 08:08 PM
puggerton03's Avatar
anybody ever try the summit 1.85 roller rockers?
Old May 16, 2009 | 09:21 PM
SweetS10V8's Avatar
Well duhh... we all know that. A real cam will make even more than the one you suggest. Hes asking about rockers.
Old Jan 4, 2011 | 10:50 PM
Blk_Ws6's Avatar
^^lmao^^^
Old Jan 4, 2011 | 11:05 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you are planning on EVER doing a cam I would just do a trunion upgrade to the stock rockers for 230$ and keep the stock geometry. Changing the ratio is really not the ideal way to get more power.
Old Jan 5, 2011 | 12:25 AM
The_Rizzle's Avatar
Not saying the trunion upgrade isn't a good idea, but on most higher ratio rockers, the geometry doesn't change any more so than using the cam to get more lift. The pushrod cup gets moved slightly closer to the fulcrum, providing more valve lift for same pushrod movement.
For a rocker like the slp, it would have the exact same same geometry, until you passed the previous max lift point.
Best solution however is to use a cam designed for a higher rocker ratio, since most good cams do take the rocker ratio into account on how the lobe creates the lift, and how fast. A high ratio on an already aggressively lifted cam could cause stability issues and valve float, while a cam designed for higher ratios might be more stable than a nearly identical cam made for lower ratios.
Cams designed for higher ratios (with same net valve lift) can usually use a larger base circle, which can help stabilize the valvetrain and increase roller lifter life.
Old Jan 5, 2011 | 01:10 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You are correct, but I was stating it merely for a reason that you pretty much touched on as well. Lots of people dont realize that certain cams have a more aggressive design and probably will cause valve float if paired with a rocker really designed to go with a stock or close to stock camshaft. Just making awareness is all. It moves geometry, but on the other end of the pushrod.
Old Jan 5, 2011 | 09:05 AM
KCS's Avatar
KCS
Moderator
The downside is that because of the increase in leverage, you will see more load at the pushrod-cup interface, and possibly a little more friction.
