Running Lean
Old May 20, 2009 | 06:55 PM
8675309's Avatar
Default Running Lean
So I've been running lean lately in the 2 and 3 cylinders. Could I need a tune to fix this? Also I have a really bad exhaust leak at the collectors. So could that have an affect on it? The leak is close to by 02 sensors. Also I dont have rear 02's. My mods are lid, h pipe, and longtubes if that would have any affect on it too. Or what else could it be?
Old May 20, 2009 | 06:57 PM
Hizicegeher's Avatar
Default Tramadol? Viagra? Without prescription!
propecia remove back hair propecia sex drive, propecia rogaine caused hair loss propecia hair loss medication, 6 propecia and rogaine and results cheapest propecia online, propecia and weightlifting christians unite propecia, regrowth hair loss propecia propecia finasteride prostate, does propecia really work for women after before photo propecia, stops hair loss propecia
Old May 20, 2009 | 07:53 PM
69LT1Bird's Avatar
I don't get why you would ask a question about your car running like crap but you rattle off a list of things wrong with the car that effects how the car runs. That rates right up there with, my car is dynoed low because I have a bad clutch or worn spark plugs.
FIX THE KNOWN ISSUES and no, a tune will not fix the 2 lean cylinders, how do you know they are lean? What tools are you using to determine there is a problem.
Old May 20, 2009 | 07:54 PM
crainholio's Avatar
Get your exhaust buttoned up before you get into tuning. Every case I've seen involving an exhaust leak causes the PCM to richen the air:fuel mixture, so it may not be the only thing wrong.
No tuner can make a GM PCM vary fueling for individual cylinders, he'd have to spoof it with external hardware. The PCM only measures each bank's exhaust output and adjusts the entire bank based on what the front O2 sensor tells it.
So how do you know cyls 2 and 3 are running lean? If you have good data showing this, it's likely that either those injectors are partially obstructed and underflowing, or your intake is leaking unmetered air at those two intake ports.
Old May 20, 2009 | 08:39 PM
8675309's Avatar
I came up on a check engine light. I poured in the sea foam and the gasket is on its way from summit so theirs not really much I can do about that. I was just trying to get some input on what else it could be
Old May 20, 2009 | 08:53 PM
crainholio's Avatar
What was the error code(s) you saw?
Old May 20, 2009 | 09:15 PM
8675309's Avatar
I'm pretty sure it was p0174 was one of them, and i dont remember the other one. And the light went away, so if it doesn't come back am I alright?
Old May 21, 2009 | 09:56 AM
crainholio's Avatar
Exhaust leaks allow air into the system, which can fool the O2 sensor into reading a "lean" burn condition.
Fix your exhaust.
Old May 21, 2009 | 10:26 AM
OMGWTFBODY's Avatar
Fix your junk, run the codes after a day or so.
Old May 21, 2009 | 02:19 PM
DIRTY_WS6's Avatar
Wink
yep you gotta fix that man
Old May 21, 2009 | 03:24 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
The lean codes are for entire banks, not individual cylinders. Get your exhaust leaks fixed, make sure you don't have a vacuum leak, and you may be god to go.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 21, 2009 | 03:39 PM
crainholio's Avatar
Originally Posted by Scoggin Dickey
...and you may be god to go.
You have high expectations...
Old May 21, 2009 | 04:01 PM
8675309's Avatar
yeah like i said I order the gasket and it should be here saturday, because nobody in town carries copper gaskets, and one of the bolts on the collector rusted out so its pretty much open headers now. And just to be safe I ran some sea foam through the gas tank to try to clean out my injectors too.
Old May 21, 2009 | 05:03 PM
crainholio's Avatar
Mr. Gasket makes a spiffy collector bolt set with interference-fit nuts that won't come loose, and they're stainless steel so no rust. Using them with copper collector gaskets has been a sure thing in my experience.
Let us know how it works after you get it together.
Old Jun 21, 2009 | 10:55 AM
8675309's Avatar
for anybody who happens to be searching for this or whatever, it ended up being my gas cap needed to be replaced.
