TR 224 Cam users question
Old Nov 6, 2003 | 06:08 PM
Josh's Avatar
Originally Posted by Paul @ Thunder
If your valvetrain is strong enough, such as good springs and pushrods then you should bend anything on just a missed shift. The reason so many stockers bend isn't really the fault of the pushrods just the crappy stock springs allowing the valves to float.
So hardened pushrods aren't really necessary if a good spring is used? I'm looking at the TR224 myself, thus my interest.
Thanks,
Josh
Old Nov 6, 2003 | 07:50 PM
Cal's Avatar
Cal
Thanks,
Josh
I don't think that's what he meant. Where he has "should" he meant "shouldn't." You want good everything; then hopefully nothing gets bent. That weak link theory is "weak."
Old Nov 6, 2003 | 08:27 PM
Ed Blown Vert's Avatar
Why is that?? If your valves float. And the pistons touch them. Something is going to bend. Wouldn't it be the weakest part??
Old Nov 6, 2003 | 08:54 PM
Cal's Avatar
Cal
Yeah but you don't want the pushrods to bend even before the valves float. It's best to build a matched system; the forces on the pushrods are much lower with the stock cam. You put a high lift cam in with fast ramps and stiff springs, then start reving the engine much higher than you ever did before; this all puts much more force on the pushrods. The valves are going to float at a much higher rpm than before with stiff springs; well over 7000 rpm with Comp 918s.
Another problem with the Weak Link Theory is bending the pushrods doesn't necessarily spare the valves; most people bend those as well. The strategy I like is building the valvetrain to withstand 7200 rpm, then put the limiter at 6750 rpm. If you have a good shifter and know how to drive, you should never shift from 3rd to 2nd anyway.
