Getting worried as hell!!! help
I would look at the wiring if its hanging and see whats up. Doesnt hurt to check it out and you might find something.
Then get it scanned and the codes read and fix the issues and then get it tuned. Same time would be good.
You can run simms or tune out the rear sensors.
check all you fluids to see if anything is getting sucked into the cylinders; when my head gasket went my motor was chugging coolant and shaking like ****.
could be a bad plug or bad wire.
could be a bad o2 sensor.
check your air filter; could be clogged and impeding the flow of air
do you have a white or blue colored steam coming from the exhaust?
2nd. you should have already tuned out your rear O2's or bought O2 sim's.
Everything sounds bad and also obvious to what your problem is.
