Valvespring shims
Old May 27, 2009 | 08:57 PM
JFM-jr's Avatar
Default Valvespring shims
Are valvespring (921's) shims for a stock GM head available in 10 or 15 thousandth thicknesses? Also is there a max figure for shimming assuming coilbind figures/clearances are met? I remember reading about too much shimming not allowing the spring to transfer heat. My installed heights are a bit over 1.8 (1.820) and I would like to shim to approx. 1.750 wich has me needing about 70 thous. I have 60's but would like the extra 10 or so for the extra spring pressure. Thanks in advance for replies.
Old May 27, 2009 | 09:07 PM
405HP_Z06's Avatar
Micro shim kits here:
http://www.iskycams.com/pdfcatalog/2004-05/page39.pdf
I used Isky part #6 when I did my Dart 225's and they worked like a champ. They come in .010", .015", .020", and .030"
Another option would be to use -.050 locks and fewer shims.
Old May 27, 2009 | 09:14 PM
SweetS10V8's Avatar
All your installed heights wont be the same, and all your springs wont coil bind at the same height. Shims come in 15,30, and 60s.
I use Comp # 4753. Its a kit and there is 16 each of .015, .030, and .060 thick spring shims.
Truly setting up your springs from coil bind on an individual basis will allow the .015" increment to get you to within .005" on each without a problem.
Old May 27, 2009 | 09:47 PM
JFM-jr's Avatar
.050 locks? Tell me more about this option Aaron thanks.
Old May 27, 2009 | 09:54 PM
405HP_Z06's Avatar
Use a valve lock that reduces installed height by .050 and then use the appropriate single shim to bring each spring to the correct height.
Old May 27, 2009 | 10:03 PM
JFM-jr's Avatar
Should I go with one method over the other? I'm looking at 2 shims to obtain these figures would I be better off with the locks you suggested and a single thinner shim?
Old May 27, 2009 | 10:44 PM
405HP_Z06's Avatar
The shim only route would be cheaper and easier, but either would work.
