Ooooohhhh f..k!!!!!!!!!!!!!!
Old May 27, 2009 | 10:35 PM
98camZ's Avatar
ok yes oil pressure came up like normal and was normal at all times 60psi when cold and after warm up 40 at idle
Old May 28, 2009 | 02:49 PM
PAGregSS's Avatar
Did you happen to install a new timing chain? Double roller? I'd start by pulling off the timing cover and check your timing set. One problem I ran into once was my ASP pulley did not clear the crank sprocket on my Rollmaster timing chain. When I tightened the crank bolt, it pushed the pulley back and pinned the crank sprocket against the block and the crank couldn't turn. I'd check to make sure you don't have anything interfering with the timing chain.
Old May 28, 2009 | 02:57 PM
fastvet's Avatar
My guess is to redo the whole thing. This time take off the heads and degree it. Maybe, just maybe the timing chain wasnt taken off dot-to-dot.
Old May 28, 2009 | 03:31 PM
TooLateVTEC's Avatar
Hooking up compressed air into the cylinders will tell you if any valves are bent.
Is there coolant in it right now? Has it ran since you towed it home?
Old May 28, 2009 | 07:49 PM
DaddySS's Avatar
It sounds like the valves hit the pistons.
Old May 28, 2009 | 10:56 PM
bigboykilroy's Avatar
Originally Posted by 98camZ
Oh also i just noticed that my valve seals are stuck up in the spring
it almost sounds like they used too long of push rods, caused way too much lift, bottomed out the springs into the valve seals, and also make piston contact.
Again not to be a dick or anyting, but yet again here is a prime example of the importance of not taking the word of people to heart, always measure your setups when you install new parts into the engine.
Old May 30, 2009 | 12:21 PM
98camZ's Avatar
ya i had stupid 7.425s in it then went to 7.4s so im sure the longer ones did it, my car used to have nos on it im thinking it may had weakin the valves also berfore i got it so myabe that wasnt so good either
Old May 30, 2009 | 12:23 PM
98camZ's Avatar
im hoping the head of the valve just stuck up in the head and all i gota do is stick new heads on it.
Old May 30, 2009 | 12:26 PM
98camZ's Avatar
u pulled the valve cover off driver side and the number 3 intake valve u can just pull it up very easy so im assuming thats the one
Old May 30, 2009 | 08:16 PM
NEMESISVETTE's Avatar
Sounds to me you may have used the wrong valve seals, just a probability. There are top hat seals that must be used with any duel valve spring. If you use the stock type valve seal (top hat looking seal) with a duel spring it will bind up and cause failure. What seals and what springs did you use?
