What cam is this?
Old May 30, 2009 | 10:30 AM
FiredUpZ28's Avatar
Default What cam is this?
I took this cam out of the Bird, so I know its for an LS1 lol, but I don't know what the cam actually is. On a completely stock a4 it ran choppy as all hell and I needed to do the idle re-learn about five times before it would stay idling.
On the cam in the third section in it is scribed/punched with this
10:24B
08002
then you flip it over on the same section its says
23:48A
07202
The guy who had it before said it was an LS6 cam, then said it was an LS6 Hotcam. But on a stock car that cam wouldn't have run so badly, at least I don't imagine. Any ideas? Thanks in advance
Old May 30, 2009 | 04:12 PM
FiredUpZ28's Avatar
No one knows? Anyone at least know of a place where I can match up grind numbers?
Old May 30, 2009 | 04:15 PM
blownws6_nc's Avatar
Man, I don't know what to tell you. Maybe someone will put you in the right direction shortly.
Old May 30, 2009 | 04:23 PM
99LSS1's Avatar
Take a picture of the end of the cam with the #'s on it and post it up. That way we can see the #'s on it. There will be someone who knows what it is.
Old May 30, 2009 | 09:47 PM
FiredUpZ28's Avatar
Thanks for the replies guys I posted the numbers as they are ground in. Unfortunately I don't have a camera that can focus that close up
Old May 30, 2009 | 09:55 PM
tremiles's Avatar
Measure it with a micrometer. If the lobe lift is different than .308 (.525/1.7) it's not a Hotcam.
Old May 30, 2009 | 10:18 PM
FiredUpZ28's Avatar
thats a good idea...... actually..... and I believe I have a micrometer but its only a 1" and the lobe is the size of the journal plus the lift so it would be bigger....
Well, thanks for the help
