Installing new heads with '02 LS6 cam
Here is all the information on the '02 cam. In the thirteenth paragraph, the GM engineer doesn't seem to think it will work well. It starts out "The '01 base circle reduction did not require..." http://www.idavette.net/hib/02ls6/page2.htm
Patriot Performance assembled heads probably use shorter than the '02 LS6 valves, right? Could this valvetrain geometry situation be corrected by using a longer pushrod or a thinner head gasket?
LPE has a very nice GT2-3 cam that is like an improved LS6 cam and offers the same or better driving characteristics and can easily pass smong. It has more intake, exhaust duration and lift. Should make better power than the LS6 and still act like an LS6 cam. There are other similar cams to consider.
http://www.lingenfelter.com/lingenfe...24&pf%5Fid=102
