help diagnosing an engine knock
Old Jun 3, 2009 | 08:57 PM
nebur8's Avatar
Default help diagnosing an engine knock
only does this when it's warmed up. Starts at about 1500rpm-3500rpm. Here are a couple of videos. it sounds like it's coming from the driver side back of the intake area.
http://s705.photobucket.com/albums/w...t=06032009.flv
http://s705.photobucket.com/albums/w...6032009001.flv
Old Jun 3, 2009 | 09:14 PM
bigboykilroy's Avatar
it kinda sounds like a bent pushrod, have you pulled the covers and checked them?
Old Jun 3, 2009 | 10:34 PM
nebur8's Avatar
i haven't pulled the valve covers yet. I havent encountered a loss of power though.
Old Jun 4, 2009 | 09:02 AM
nebur8's Avatar
when i remove the valve cover, what should i look for as an indication of a problem with the pushrods?
Old Jun 4, 2009 | 01:10 PM
SOMbitch's Avatar
Take the rocker arms off. Then pull out the pushrods and roll them on glass tabletop or other flat surface and see if one is bent.
Old Jun 4, 2009 | 05:51 PM
nebur8's Avatar
any other opinions?
