Pushrods and ls7 lifter question
This is my motor as it sits now, im awaiting my new pushrods.
i installed a new cam (228, 232, .590, .590 @ 113lsa) and it blew one of my already failing LS1 lifters out. replaced the lifters with LS7s and then valvetrain noise took over my life. when the oil got hot, it would CLACK CLACK CLACK like crazy, something you could hear from a block away... literally.
so, i had another NEW set of LS7 lifters installed yesterday and im hearing some of the same noises, just not as pronounced.
im ordering a PR length checker today, my question is this: if i have ~300 miles on the new LS7 lifters and the preload is too much (runnin the TSP 7.40 PRs now) will changing the pushrods out do anything? will it correct the problem (assuming PR length is it) or do the lifters 'set' themselves to the pushrod in some way?
thanks!
ME:
Patrick, I have decided to change my lifters to LS7 lifters when I do the cam swap. You recommended 7.425" pushrods with stock lifters. Should I go with a shorter pushrod now that I am going to be putting LS7 lifters in? Thanks for your help.
Patrick G:
The LS7 lifters use the same preload as LS1 lifters. The 7.425" pushrods will work well in this case.
Patrick Guerra - The Guerra Group - 114 Spokane Avenue - Victoria, Tx. 77904 -
ME:
Patrick G:
ME:
Patrick G:
So if the 7.425 get you let us say .100 preload or more on LS1 lifters, that would be like .125+ in LS7 and that would make it too close to plunger bottoming out.
So bottom line, measure instead of shooting a dice roll.
