Pushrods and ls7 lifter question
Old Jun 5, 2009 | 01:39 AM
fccs's Avatar
Default Pushrods and ls7 lifter question
My motor will be back together this week, I have ls7 lifters now and wanted to know if I should expect the standard 7.4's to be to long? I've been hearing ls7 lifters change the pushrods length but I just felt like asking so I know what to expect ahead of time. Thanks
Old Jun 5, 2009 | 05:31 AM
cookba's Avatar
your best and safest bet is to get a pushrod length checker (there only like $20). this way you get exactly what you need and dont risk damaging your block.
Old Jun 5, 2009 | 10:32 AM
mtjoy's Avatar
^^^What he said about checking the pushrod length. When I changed from stock LS1 lifters to LS7 I went from a 7.4 to 7.35" pushrod.
Old Jun 5, 2009 | 05:12 PM
00SS6spd's Avatar
I'm with them. Check for proper pushrod length, the LS7 lifters aren't the same as the LS1's.
Old Jun 6, 2009 | 02:14 AM
fccs's Avatar
I will check, im just wondering what to expect since that means ill have to send them back to tsp for a different size ahah. How about this way, how many people are running 7.4's with ls7 lifters out there? My heads are not milled and from what I hear the ls7 lifters are the exact same size as the ls1 lifters?
Old Jun 6, 2009 | 08:08 PM
00SS6spd's Avatar
If I'm not mistaken, the LS7 lifters are the GM replacement part for an LS1 lifter now, but they are NOT identical. I believe they require a slightly shorter pushrod than stock to achieve correct preload with an otherwise stock setup.
Again though, determining correct length for your application depends on multiple factors in your setup.
Old Jun 10, 2009 | 05:40 PM
fccs's Avatar
Yea.. had to order 7.35 pushrods from tsp. Christ... its something new every week, is this car ever going to be done??
Old Jun 11, 2009 | 10:23 AM
383lt1impala's Avatar
How u figure out u need shorter ones? The engine place told u?
Old Jun 11, 2009 | 12:44 PM
fccs's Avatar
I measured with a adjustable pushrod.. like I was going to anyways lol
Old Jun 11, 2009 | 03:49 PM
2002 SS HUGG's Avatar
Yes, you are correct, the LS7 lifters are .05 longer than stock LS1 lifters. This difference in length will require a pushrod of 7.35 to put you within the range of stock preload. Of course, some individuals have used a 7.325 pushrod to reduce valvetrain noise and change their lifter preload. I think your choice in a 7.35 pushrod will suffice. However, make sure to use the length checker to assure you are within a safe and reasonable preload. I believe the LS7 lifters operate best between a .06 and .09 preload. Different lifters (MOREL, COMP, LUNATI, LS7) operate better at different preloads and have different suggested preloads. However, the amount preload best for each individual engine is debatable. Hope this helps.
Old Jun 11, 2009 | 04:20 PM
PREDATOR-Z's Avatar
Overall yes you are correct but LS7 lifters are not longer/taller, the cup sits higher than it does on OEM LS1/LS6 lifters.
See pics attached LS7 on left
Attached Thumbnails Pushrods and ls7 lifter question-ls7-20lifter.jpg   Pushrods and ls7 lifter question-ls7-20lifter-20comparison.jpg
Old Jun 11, 2009 | 04:33 PM
TooLateVTEC's Avatar
Excellent pics Pred-Z...thats something ive been wanting to know as well....just b/c.
Thanks
Old Jun 11, 2009 | 05:21 PM
Legman's Avatar
I've read .060 to .120 preload is acceptable. I measured 7.331 pushrod length at zero lash and went with Manley chrome-moly 7.4's that actually measured out to 7.411. Puts me right at .080. I have very mild valvetrain noise but then I am using Yella Terra ul's too.
Old Jun 11, 2009 | 09:36 PM
DustinWS6's Avatar
What would be the negative effects of running a 7.4" pushrod with the LS7 lifters? I just swapped heads and changed over to the LS7 lifters. I just reused my Manley 7.4" pushrods from my cam swap a few years ago.
Old Jun 11, 2009 | 10:56 PM
fccs's Avatar
Yea 7.4's were way to long, 7.35's were almost perfect right in the center so thats what I have coming.
Old Jun 12, 2009 | 04:45 AM
PREDATOR-Z's Avatar
The ONLY way to truly answer that Q is to measure. What you want to avoid is putting too much preload >.100
If you go over that you run the risk of lifter damage, hanging valves open and even PTV contact.
Old Jun 12, 2009 | 01:23 PM
Uncle John's Avatar
When I used the 7.4 rods I had ZERO static compression. Measured with rod checker and wound up needing 7.325 for .075 preload. (5.3 heads unmilled, MLS gasket, LS7 lifters, stock rockers)
Old Jun 12, 2009 | 01:37 PM
DustinWS6's Avatar
I have the same setup except I used the GM Graphite gaskets. Looks like I may also need shorter pushrods. Could you explain the zero static compression to me?
Old Jun 12, 2009 | 02:33 PM
PREDATOR-Z's Avatar
means his valves were hanging open, so no compression in cylinder.
Old Jun 12, 2009 | 06:57 PM
Stewart Leask's Avatar
could you guys possibly see a 7.4 pushrod coupled with 1 ls7 lifter (only one was bad and I was told these are identical much like the other people in this thread) creating oil pressure issues? or is the lifter going to have to fail before i see oil pressure issues?
