head gasket?
Old Jun 6, 2009 | 08:08 PM
Fun-Formula98's Avatar
Default head gasket?
Whats a good head gasket to use when installing a new set of heads.... Maybe a thinner gasket to bump up the compression a wee bit???
Old Jun 6, 2009 | 10:48 PM
5.3LJimmy's Avatar
A thinner gasket can be good, it just depends on the application. List all the details of your setup so we can make a good recommendation.
Old Jun 7, 2009 | 10:52 AM
GM hot cam, ls6 intake, ls6 heads<--- ((i may get some work done on them... i dunno yet)) LT's, y-pipe, SLP LM1, and a few other bolt on's. SLOW haha
Old Jun 7, 2009 | 05:25 PM
::bump:: ???
Old Jun 7, 2009 | 06:41 PM
got-a-ls1's Avatar
i went with cometics. i think they're some of the best and some say reusable .... have a lot of different thicknesses also. also no cleaning if you take them off like the stock graphite mess.
Old Jun 7, 2009 | 08:54 PM
jrpimp00's Avatar
I use GM MLS, but my heads are milled to 59cc..You can get them pretty cheap. I Think i paid $36 for a set shipped to my door.
Old Jun 7, 2009 | 11:05 PM
5.3LJimmy's Avatar
If you aren't having the block resurfaced then GM MLS is more forgiving to imperfections. The cometics require a flat surface and specify an RMS range for the machined deck finish. Most people use them without issue, but a few have had sealing problems. With your cam you really don't need a large bump in compression to achieve optimum results, so I say mill the heads to 59cc and run the GM MLS.
Old Jun 11, 2009 | 08:43 PM
Thanks guys!
Old Jun 11, 2009 | 10:18 PM
SOMbitch's Avatar
The Cometics are $150+ IIRC and I musta got ripped on my GM MLS cause I think I paid $58
