Will GM 6.0 gaskets work on a 4.080 bore?
Old Jun 7, 2009 | 01:34 PM
Nitrojunkie's Avatar
Default Will GM 6.0 gaskets work on a 4.080 bore?
Like the title says Im installing the heads on my LQ9 with a 4.080 bore and Im wandering if stock GM head gaskets will work. Thanks in advance!
Old Jun 7, 2009 | 04:20 PM
NemeSS's Avatar
6.0 are 4.045 = no go
need ls3/ls9/l92
4.1 bore = go
or some cometics
Old Jun 7, 2009 | 04:21 PM
69LT1Bird's Avatar
nope, the 6.2L is closer, I believe they are 4.070"
Try Cometics.
Old Jun 7, 2009 | 04:25 PM
NemeSS's Avatar
Try Cometics.
i would just go with cometics as well for that size bore
Old Jun 7, 2009 | 04:37 PM
Thanks guys. Your right I should just go with cometics. I guess Ive gotta sit down and figure out what thickness I need... I ran 6.0s last time I pulled the heads but they leaked so I questioned the GM 6.0 gaskets. Thanks again.
Old Jun 7, 2009 | 06:43 PM
PREDATOR-Z's Avatar
You should run a good .015/020 size bigger than your bore or head chamber bore (which ever is bigger)
part # 12610046 LS3/L92 gasket is what you need.
Old Jun 7, 2009 | 08:43 PM
Thanks again guys. Are the LS3/L92 head gaskets the same as the LQ4/LQ9 other than bore diameter?
Old Jun 7, 2009 | 09:27 PM
sroach20's Avatar
no, they are 5-layer instead of 3.
Old Jun 7, 2009 | 09:43 PM
Ahh good deal. Definitely not a bad thing. All the oil and coolent passages are the same Im guessing?
Old Jun 8, 2009 | 03:10 AM
PREDATOR-Z's Avatar
Ya, ya
