PTV Clearance Torquer V.3/ PRC 243's
The cam will clear and you will not have PTV issues (no more than any of the big cams out there).
Since you allready have the cam, no point in changing now. just make sure you get the right springs to match. I prefer PAC 1521 duals. Install height 1.770.
Pushrods will have to be measured and idealy you should run different length intake and exhaust (but not necessary).
Thicker p-rods will benefit you on those lobes (for better stability at high rpm), 11/32s or .105 5/16th (standard is .0800)
That is if you want to do this right and control your valvetrain better.
