59cc head guys......
Old Jun 8, 2009 | 11:11 PM
Gregorya24's Avatar
Default 59cc head guys......
what size camshafts are yall running on stock bottom end cars?
Old Jun 9, 2009 | 01:11 AM
2001ws6-500hp's Avatar
buddy of mine, "brake" runs an ms4 on a 59cc
Old Jun 9, 2009 | 02:43 AM
bighamz28's Avatar
torquer v.2 w/.040 cometic head gasket no prob
Old Jun 9, 2009 | 09:04 AM
Gregorya24's Avatar
are you on stock pistons or flycutted ones? i was planning on running 228r cam
Old Jun 9, 2009 | 09:09 AM
brad8266's Avatar
Thats a very bad idea.
Old Jun 9, 2009 | 09:11 AM
ss2000's Avatar
ms4, .040 cometics and flycut for intake valve only.
Old Jun 9, 2009 | 09:12 AM
Gregorya24's Avatar
wow i should be able to clear a 228 or torquer v2 cam then
Old Jun 9, 2009 | 09:19 AM
brad8266's Avatar
You guys that think that just because a cam clears that it is safe to run it need to take a basic engine building course or something.
A 228 cam will clear 59cc heads but will probably be kinda close on stock pistons.
I was running a 232/236 .585 cam (pretty much a TQv2 I believe) on some 57ish cc heads with pistons with -2cc of relief. I actually measured my clearances and I was pretty much right at your safe clearances(.080 Intake/.100 Exhaust). If I had stock pistons there probably would have been some contact.
My point is you shouldnt ask on the internet if it will fit, you need to take the measurements on your particular setup and if its too close you need to decide if you want to run it like that or you would rather change your setup slightly to give you an accepatable clearance.
Old Jun 9, 2009 | 09:23 AM
Gregorya24's Avatar
brad what would you think of a 228r with a 45" thick gasket instead of stock gm gasket? i just dont wanna order the wrong camshaft go to check clearences and it doesnt clear
SSwt00SS's Avatar
setup im running:
partiot 59cc Ls6 stage II heads, with a LITTLE comp 224/.581/112lsa, ported 90/90, LT's/TD, supporting mods, putting down 458/410 to the ground. she runs like a raped ape...
car is m6, stock 10-bolt, 3.42 gears, stock bottom end, no flycutting...
Old Jun 9, 2009 | 09:27 AM
ICRAZY6's Avatar
I'm running a TSP 231/237 with stock gasket and there's plenty of clearance.
Old Jun 9, 2009 | 09:31 AM
SSwt00SS's Avatar
i regret selling my 231/237, but i wanted to max out that 224 before considering going larger. now if i do, i will go custom grind...
i remember talking with you quite a bit about the 231/237 cam. the guy i sold it to is now trying to sell it over on Ls1.com, since he sold his TA...
Old Jun 9, 2009 | 09:35 AM
brad8266's Avatar
It will clear ok, I just recommend you measure your clearance when you do the install for piece of mind. Its not hard to do.
Gregorya24's Avatar
Originally Posted by SSwt00SS
setup im running:
that is exactly what i got except ported advanced induction heads, so looks like its gonna be the 228/228 588"/558 on a 112 for me
Old Jun 9, 2009 | 09:36 AM
Gregorya24's Avatar
thanks i appreciate it man, i will def check all clearances before firing over
Old Jun 9, 2009 | 10:37 AM
PREDATOR-Z's Avatar
Also guys check your DCR. If you have to high a DCR, you are going to run into detonnation issues.
Or you'll be forced to run lower timing to compensate and therefore negating any benefit of adding coompression.
Choose your parts carefully based on the fuel you'll run as well.
Old Jun 9, 2009 | 11:08 AM
allthrotle's Avatar
Im running a 228/230 with .585/.585 on 112lsa.
Old Jun 9, 2009 | 11:18 AM
Gregorya24's Avatar
ok cool thats almost identical to the 228r camshaft
Old Jun 9, 2009 | 11:24 AM
jrpimp00's Avatar
Small 224r/.581 114 here with stock gm mls gaskets.
Old Jun 9, 2009 | 03:48 PM
Sigforty's Avatar
I ran a Futral F14 with 58 cc heads and the stock GM MLS gasket without issues.
