knock sensor Q
I had the intake off and decided to change the knock sensors since it was off and they looked bad. I did this and put everything back together and now I have an SES light. Its for the knock sensor. Any idea why?
Did you run the wiring the same route? Could be the plastic lips on the bottom of the intake crushed one? If you cut them off with a chisel when doing the intake, then all I can think of is that one didn't get plugged back in right.
Kind of like this guy did.
