What am I missing (double roller)
Old Jun 9, 2009 | 03:04 PM
brianfromhawaii's Avatar
Default What am I missing (double roller)
I was givin a double roller setup, but I KNOW KNOW KNOW some parts are missing... anyone wanna chime in as to what parts are missing?
Attached Thumbnails What am I missing (double roller)-downsized_0609090954.jpg
Old Jun 9, 2009 | 04:26 PM
vettenuts's Avatar
Driver for the oil pump and oil pump spacers. That, to me, is a paper weight.
Why would you put a used setup with parts missing into a motor if the part in question, should it fail, would cause thousands in damage and possible the motor?
Old Jun 9, 2009 | 04:43 PM
its very very slightly used and in excellent condition i found a pic someone pmed me that has 2 spacers (it looks like) and some bolts... otherwise it has the same stuff as what im showing here.
Old Jun 9, 2009 | 05:07 PM
vettenuts's Avatar
You don't have the oil drive gear. Look at this link and then click on the photo.
Link
Old Jun 9, 2009 | 09:49 PM
hmmm ok... but in this pic..
http://store.msperformanceonline.com/55000.html
it looks like im good to go... hmm
Old Jun 9, 2009 | 09:54 PM
JFM-jr's Avatar
You posted a question that Vettenuts has given you a specific (and correct) answer to. Take his answer for what it's worth (he gives VERY good info 99.99% of the time ).
Old Jun 9, 2009 | 10:15 PM
01ssreda4's Avatar
I have to agree here. Go with what you got and you will soon see you have no ******* oil pressure. You NEED the oil pump drive piece.
Old Jun 9, 2009 | 10:35 PM
well, thats why said hmm and was asking.... any idea if this would be left on the oil pump or something? or can i buy these buy themselves?
Old Jun 10, 2009 | 04:27 AM
vettenuts's Avatar
I have personally never seen these sold separately, but that doesn't mean you can't get them. I guess what I meant in the first post is that the set is not complete and the chain is used. In my opinion, by the time you get the missing pieces you are better off just buying a new set. What are you running for a setup? A brand new LS2 chain will run on stock sprockets and is less than $40.
Old Jun 10, 2009 | 04:29 AM
vettenuts's Avatar
Look closely as that picture and your parts, the part that drives the oil pump is separate in your setup whereas in the one you posted in this link it is integral with the sprocket (like the stock setup).
Old Jun 10, 2009 | 08:02 AM
PAGregSS's Avatar
I can't tell unless the cam sprocket is flipped, but also looks like you're missing a torrington bearing, if that brand came with one.
Old Jun 10, 2009 | 01:38 PM
oh **** yeah its that thing that looks like a giant washer... maybe ill just get an ls2 chain... thx vette nuts.
