choppy or not
Old Jun 16, 2009 | 01:19 PM
nasty2000z28's Avatar
Originally Posted by PREDATOR-Z
LOL, this is a hot cam 112+4 LSA (not a 108 LSA but 108 ICL)
9* overlap
I was like WTF?
NO! its actually 108lsa. the standard hot cam is 112. this one is the stage 2.
here it is.
https://store.gmperformanceparts.com...-88958722--%3E
Old Jun 16, 2009 | 01:54 PM
WeathermanShawn's Avatar
Wow ,never seen or heard of that cam.
Whats the verdict on the amount of cam overlap? I trust Pred-Z's calculations so much, I didn't even double-check when I posted.
Not knocking the cam..just curious on what lobes it is running. Its has an unusual split, but I am sure it serves its purpose.
Just trying to learn here.
..WeathermanShawn..
Old Jun 16, 2009 | 02:00 PM
sounded like a good cam when i was reading about it in the gm catalog. something mild with a choppy idle is all i wanted. it works well for me. next are the 799 heads im porting intake and stall.
Old Jun 16, 2009 | 03:42 PM
PREDATOR-Z's Avatar
Wow, doesn't sound like 17* overlap, if indeed it is on a 108 LSA. Sounded good actualy.
The calculations are correct if on 108 LSA (WeathermanShawn) 17*
First time I see this one.
I saw Hot cam (didn't pay attention to stage 2) actualy it doesn't say Hot Cam on site it just says stage 2 (unless I missed something again...)
Hot cam is 219/229 112LSA, 0* overlap.
What exhaust do you have on?
Old Jun 16, 2009 | 03:57 PM
Lt's, true duals, x-pipe with bullets dumped. i have pics in my album. i still have to do my heads, intake, stall and a tune yet. hopefully soon.
Old Jun 16, 2009 | 04:12 PM
PREDATOR-Z's Avatar
Sounds good, maybe because it was in open air. Do you have any dyno results?
Old Jun 16, 2009 | 04:50 PM
ramdaspadhye's Avatar
Off topic, but look at that stage 3 cam :o
http://videos.topredline.com/recentv...5c00ff1be4.htm
Old Jun 16, 2009 | 06:02 PM
Titanws6's Avatar
Predator, just curious, how does this sound compared to your cam spec'd
230/230 .612/.592 111+2 LSA
Chop, lope, I can't tell the diffrence, this cam sounds good and am hoping yours will sound similar.
Old Jun 16, 2009 | 06:28 PM
PREDATOR-Z's Avatar
http://www.youtube.com/watch?v=LpU-C...eature=related
First through exhaust (I forgot what catback), then with cutout open.
Rapid popcorn
Same car at the track
http://www.youtube.com/watch?v=xKAo7...eature=related
Old Jun 17, 2009 | 10:00 AM
before the cam i made 306hp and 321 torque
Old Jun 17, 2009 | 10:33 AM
PREDATOR-Z's Avatar
Good that is baseline so now Dyno again and find out how much you gained. (I would be curious if I were you)
Old Jun 17, 2009 | 10:38 AM
  #32
i will. just have to get the rest done first. i just picked up my valve springs last night. so ill finish porting this weekend and get those on. i just need to find an ls6 intake and pick up a torque converter. then ill be off to get tuned. im hoping to get at least 400rwhp.
Old Jun 17, 2009 | 05:20 PM
  #33
Titanws6's Avatar
Rapid popcorn
Nioce! Man, I cant wait to get it in, very very soon here!
Old Jun 17, 2009 | 09:31 PM
  #34
Nitroused383's Avatar
Tuning makes all the difference in the world with idle. I noticed when I installed flow matched injectors my car idled much smoother. My car has over 10 degrees of overlap and idles smooth, you cannot even hear it loping inside the car. Exhaust also makes a huge difference, through my slp dual dual it is very tame. With the cutout open it sounds like a dragster.
Old Jun 17, 2009 | 09:43 PM
  #35
user 648967286742's Avatar
i cant wait to see the results with this cam. should be interesting. sounds nice by the way.
Old Jun 18, 2009 | 07:32 AM
  #36
mook99ta's Avatar
Hey predator what is done to that car? Is it a Cam only auto? What tires are you running?
Rapid popcorn
Old Jun 18, 2009 | 11:31 AM
  #37
PREDATOR-Z's Avatar
That is another member's car. Chrs1313
Yes cam only, auto, SS4000 yank stall, stock dif (3.23) + bolt ons, 3350lbs.
Old Jun 19, 2009 | 04:05 PM
  #38
Predator, what kind of power do you think i'll make with my setup?
Old Jun 19, 2009 | 04:07 PM
  #39
Oh, my heads are ported 799s, ls6 intake. i want a 3600 stall and i have 3.73s out back
Old Jun 19, 2009 | 05:13 PM
  #40
PREDATOR-Z's Avatar
Rhat is do difficult to say, I have not seen that cam in the works yet. That is why I am curioud to drr s dyno graph to look at the curves.
Should brake 400, maybe 415/400trq (just a shot in the dark)
