interesting !! how many rpm or hp are the stock open face ls1 lifters rated for mine are new and i was planning on using them do i need to change to the ls7 and new pushrods or will i be ok i will be peaking out about 6200-6400
I have used LS7 lifters WELL past 7200 with spring pressures you would not believe. You will be fine...
Thanks. I have never had a lifter failure in all my years of doing this. The only problems I see with stock type lifters is due to incorrect valvetrain setups leading to instability and lifter guides getting old and failing...
Shane
Im usually not a necro bumper but since this thread is very highly ranked in Google I thought I would dig it up. Ive been doing some research as I detected the LS-7 pushrod cup depth myself when using Comp Cams pushrod checkers. I measured it with a micrometer and got 0.060 shallower. I used a different method that im not the originator of but I feel is far more accurate. It is however not something the LS guys will like due to the fact you have to pull the heads on LS motors, unlike SBC's to get to the lifters. This is why I only use it when building a new/custom motor on an engine stand.
But I wont go into further detail on that unless its warranted and would need to be a fresh post.
The reason for the reply here is Cajun's method is sound for one, "critique". The use of the torque wrench I feel only adds inaccuracy and variation between users. Once the rocker is fully seated/mated to the head, any further rotation of the bolt is only adding stretch to the fastener and not affecting lifter pre-load. I feel the procedure would be much more accurate if people simply hand tightened until fully seated.
