Is this a good plan, (cam, stock heads, headers 99+ LS1 A4)
I have a 99 Trans Am with the following mods:
All free mods from LS1tech/ls1.com
ASP Underdrive Pulley
SLP Air Lid w/K & N
SLP Smooth Bellows
SLP 85mm MAF
Hooker Cat-back
3.73 gears
TCI Super Streetfighter 3500 stall
B & M Tranny Cooler
BMR Lower Control Arms w/relocation brackets.
LS1 Edit & Dyno tuned by Delk Performance.
Mods I am planning on doing. I'm wanting to get as close as I can get to 400 wheel hp.
Pacesetter LT Headers w/y-pipe
LS6 Intake
TR227 Cam or MTI X1
Replace springs, rockers, etc.
Rear Girdle
With this setup, what will I possibly be looking at to the wheels, best guess? And is this cam good enough or will I need bigger, smaller??
It's a daily driven car, so not wanting it to stall out on me, etc. But if it runs really mean, that's fine in my book.
This will be probably only mods for this next year, '04.
I'm probably going to eventually put a stage II or III heads with whatever big cam I throw in there now, and depending on what kind of boost I can use, I was wanting a Vortech V-9 SQ G-trim running 5-6psi.
Thanks
SLP Air Lid w/K & N
SLP Smooth Bellows
SLP 85mm MAF
Hooker Cat-back
3.73 gears
B & M Tranny Cooler
LS6 Intake
TR227 Cam or MTI X1
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Rear Girdle
Thanks
SLP Air Lid w/K & N
SLP Smooth Bellows
SLP 85mm MAF
Hooker Cat-back
3.73 gears
B & M Tranny Cooler
LS6 Intake
TR227 Cam or MTI X1
Rear Girdle
Thanks
SLP Air Lid w/K & N
SLP Smooth Bellows
SLP 85mm MAF
Hooker Cat-back
3.73 gears
B & M Tranny Cooler
LS6 Intake
TR227 Cam or MTI X1
Rear Girdle
Thanks
your car wont have and driveability problems either...
just get ready for the eventual rearend/tranny problems...
Yea I was thinking about the rear. Guess not being practical I'll get the go fast goodies first and only rear stuff is the girdle to handle for alittle while.
I'm guessing it should hold up long enough for me to save up for a replacement.
I want to get the tranny rebuilt and ofcourse go to a 12 bolt rear end. Just going to be awhile before I go that route.
SN95 Director
pick one or the other; n/a cam or blower cam. i'd look at the TR230 over the TR227 if your considering things like the MTI x1 cam. you'll get more power out of the t230. you'll need a good tune though for both considering the tr230 is a 111lsa and the x1 is on a 112lsa. the x1 and 230 are very similar except the x1 has a higher lift and a slightly bigger exhaust duration.
for the blower you'll want a traditional split cam, more exhuast duration, and you'll want a higher lsa 116+ so you dont bleed off the boost. check with the FI guys in there forum for more specifics on blower cams since its not my avenue.
with your mods and the cams you suggested i'd say you'll be around 370 with tune. if the car is strictly your daily i'd consider the tr224 on the 114, makes great power in the midrange and when you get heads you should be over the 400rwhp mark.
heres a TR cam comparison jason posted, all the mods are the same exept for the cam swap. pm him if you want specifics or anything. car is an m6.
http://members.***.net/kcr19/TRcam_comparison.jpg
