Lifter preload question
Old Jun 19, 2009 | 11:20 PM
Mike94ZLT1's Avatar
Default Lifter preload question
I'm redoing my valvetrain, and I'm measuring out my pushrods. Following Vettenut's instructions I have determined that my car likes between 11 and 11.25 turns to get the rocker snug, so if I go off 11.125 turns I am right at 7.35625. How much preload should I add in? I'm going to try and run out and grab these pushrods in the morning. Thanks!
Old Jun 20, 2009 | 04:22 AM
DaddySS's Avatar
.080 for stock lifters would put you at 7.43625 so the stock 7.4s will be a bit loose, 7.425s would be better, 7.450s would be nice and and quiet although some would say it is too much preload.
Old Jun 20, 2009 | 04:28 AM
PREDATOR-Z's Avatar
What type lifters are you running?
Old Jun 20, 2009 | 07:47 AM
Mike94ZLT1's Avatar
LS7 lifters. Sorry I didn't specify. Yella Terra rockers too.
Old Jun 20, 2009 | 08:10 AM
PREDATOR-Z's Avatar
If your calculation is correct then 7.425s
Are you sure you measured on base lobe of cam with piston at TDC?
Old Jun 20, 2009 | 08:40 AM
Mike94ZLT1's Avatar
Yes, on cylinder #2, the piston was at the top of the cylinder and both valves were closed. Will the 7.425's quiet it down some? A few of my lifters have collapsed or bled out when the engine was sitting and it only ran for a few seconds, so I know some of the noise was from that.
Old Jun 20, 2009 | 05:47 PM
Mike94ZLT1's Avatar
7.425's quieted it down quite a bit! Much quieter than it was with those trashed HS modded stockers!
Old Jun 20, 2009 | 05:52 PM
PREDATOR-Z's Avatar
Enjoy....
Old Jun 20, 2009 | 06:35 PM
Mike94ZLT1's Avatar
Enjoy....
I will, thanks guys! I almost think I could get a 7.45 in there, but I don't feel like spending another $100 on it.
Old Jun 20, 2009 | 07:28 PM
Black Sunshine/ 00SS's Avatar
Did you have some lifter issues that contributed to the valvetrain noise? Now that I've got a quieter exhaust on the car, I realize the valvetrain noise more.
I've been thinking of Morel lifters, and Yella Terras, whenever I have the motor freshened up in the future.
Old Jun 20, 2009 | 09:32 PM
Mike94ZLT1's Avatar
I think they just weren't pumped up all the way, and the slop in the valvetrain from the short pushrods made it worse. Sounds good now! Still kinda noisy but its to be expected!
