Sleeper cam
Old Jun 20, 2009 | 11:51 PM
94dragbird's Avatar
Default Sleeper cam
I'm thinking about putting a cam in my 99 Z28 to go along with the LS6 intake and PP TB. I want something that I can preferably use with a stock stall or maybe a 2200 stall. I want it to be a real sleeper. I'm not looking for max hp or tq, just want to run around 7.6X or a little faster in the 1/8 mile. Any suggestions?
Thanks, Mike
Old Jun 21, 2009 | 12:00 AM
ramdaspadhye's Avatar
tr220 on 114
Old Jun 21, 2009 | 01:42 AM
Arc00TA's Avatar
I agree, any of the small cams (220,224, maybe 228) on a 114 or 116 LSA will be good sleepers, keep some cats on for extra quietness.
Old Jun 21, 2009 | 01:54 AM
Yeah, don't bother with high flow cats. The stock ones flow just fine. Magnaflow muffler + cats + higher LSA cam = quiet
Old Jun 21, 2009 | 01:58 AM
ChevyRyda99LS1's Avatar
228 is not a sleeper I am running that on the 114 and its sounds pretty loud maybe because I have longtubes and no cats but its not a sleeper not a big cam but no sleeper cam, 220 on 116 would be more sleeper
Old Jun 21, 2009 | 02:05 AM
94dragbird's Avatar
I just ordered a magnaflow and the previous owner cut the cats off. I'm eventually going to do headers and a Y since the cats are gone. What kind of times can I expect in the 1/8 mile with the 220 cams? 224?
Old Jun 21, 2009 | 02:49 AM
Third Gear's Avatar
LOL, it's not going to be a sleeper with no cats! If you want it to be a sleeper you need something with a wide LSA. There are lots of choices out there. Thunder and Lingenfelter have nice cams that will sound almost like stock.
Old Jun 21, 2009 | 02:55 AM
a 114lsa with the proper tune will have very little lope to it in the 220 duration range...
Old Jun 21, 2009 | 02:58 AM
http://www.youtube.com/watch?v=fiigGzcPy1o
that's a tr224 with stock exhaust and manifolds, on 114lsa...
Old Jun 21, 2009 | 06:32 AM
PREDATOR-Z's Avatar
Thanks, Mike
Hi Mike,
219/223 .607/.610 111+1 LSA
If you are going to stall it, 2800 stall (2.0>2.2 str)
Old Jun 21, 2009 | 12:40 PM
IWGF's Avatar
Listen to tha Predator. Or get to the choppa. Your choice son!
Old Jun 21, 2009 | 12:59 PM
1969mach1's Avatar
Originally Posted by PREDATOR-Z
Hi Mike,
Hmmmm. very nice.
Old Jun 21, 2009 | 02:59 PM
94dragbird's Avatar
Hi Mike,
What kinda of times will something like this put down on the 1/8 mile with supporting mods and full bolt on minus water pump? How long will the springs last with that kind of lift and would I NEED a stall?
Old Jun 21, 2009 | 03:17 PM
DVS99TRANS's Avatar
Damn that is alot of lift for a small cam. As long as you warm the springs up like they are supposed to before hammering it and heat cycle them. A while... lol. You will run mid 7's with that honestly.
Old Jun 21, 2009 | 03:25 PM
94dragbird's Avatar
Well my buddy ran 7.50 with his 408 so I would like to get close to that. Don't ask why it was so slow.... If I can get with in a tenth I can take him easy.
Old Jun 21, 2009 | 06:48 PM
Mumbles's Avatar
I don't have any experience with camshafts yet. (And I must stress the "yet.") But I've come across this on youtube a couple of times. This makes me wanna do something similar. Check it out.
http://www.youtube.com/watch?v=H7EBu4pCvZs
Old Jun 21, 2009 | 07:06 PM
Pretty sure that one hasn't been tuned... that cam has -8 degrees of overlap and should have a MUCH smoother idle when tuned properly
Old Jun 21, 2009 | 09:47 PM
94dragbird's Avatar
Hi Mike,
Anybody have a sound clip of something close to this? Will it still be half way smooth with the 111 LSA?
Old Jun 21, 2009 | 10:02 PM
DiabloFormula's Avatar
Gone 7.5@93MPH in the 1/8 with my setup so far and she still has a little left in her too.
Old Jun 21, 2009 | 10:08 PM
94dragbird's Avatar
That would be plenty good for me. Just wonder how the cam predator speced me sounds at idle.
