Timing chain and gears
Old Jun 22, 2009 | 08:29 AM
datz kool's Avatar
Default Timing chain and gears
At what mileage should an ls motors timing chain be replaced.
And whats a good replacement chain.I might be ready for one,car has over 50 thousand miles on it.
Just looking to keep it safe.
thanks......
Old Jun 22, 2009 | 08:52 AM
eseibel67's Avatar
Gears will last forever.
At 50K, you're chain is likely still o.k.
When the time comes, LS2 chain has thicker links, is a direct fit on the stock gears, and can be had from SDPC for $40.
Old Jun 22, 2009 | 09:00 AM
datz kool's Avatar
Thanks, I will look into the ls2 chain. For 40 bucks its good insurance.
Old Jun 22, 2009 | 09:12 AM
wicknewman's Avatar
Well, if you are going to the swap the timing chain out you may as well put in a cam . It will be right there and you have done almost all the work to get to it. Scoggin Dickey has a good selection of those as well.
Old Jun 22, 2009 | 09:18 AM
datz kool's Avatar
[QUOTE=wicknewman]Well, if you are going to the swap the timing chain out you may as well put in a cam . It will be right there and you have done almost all the work to get to it. Scoggin Dickey has a good selection of those as well.
Please dont tempt me The motors only a baby stopped making power at 5800 rpm. Damn slowhawk - mustang dyno
Old Jun 22, 2009 | 09:29 AM
wicknewman's Avatar
You are only giving yourself more reason to do it by saying that.
Old Jun 22, 2009 | 04:39 PM
01ssreda4's Avatar
i say swap it at 50k. its cheap insurance.
Old Jun 23, 2009 | 02:01 PM
SKI's Avatar
SKI
Good for a 100+ miles.....
Old Jun 23, 2009 | 02:20 PM
02*C5's Avatar
if stock 100k if work done (ie head/cam) I would say 50K after the job. Specially if your shifting points are now between 6500-6800 on a LS1/6800-7200 LS2/LS3
