1.8 rockers with this cam
Old Feb 16, 2003 | 10:55 PM
cruzerbobby01's Avatar
Default 1.8 rockers with this cam
Do you guys think I can run 1.8 rockers with my comp cam 224-228 563 lift with a 112 center?
I have new comp 918 springs. Milled the heads 30 thsnd. Heads are stage 2 ported 202int 157exh.
Do you think the 918 will last.
Old Feb 17, 2003 | 07:48 PM
Default Re: 1.8 rockers with this cam
I could really use your advice.
Old Feb 17, 2003 | 08:30 PM
rwb's Avatar
rwb
That cam is too much. Go to Thunder Racings web site and look at cam specs that are OK with 1.8. I am running a 218/224 compcam, and I think that is as big as you can go with 1.8rrs. Keep a close eye on them as mine loosen up every now and then.
