help with knock sensor
Old Jun 23, 2009 | 09:33 PM
98z28bitcha's Avatar
Angry help with knock sensor
My frist knock sensor being a pain in the *** its rust so bad it keeps striping i can break it lose. Is there a another way to break it lose?
Old Jun 24, 2009 | 09:14 AM
anyone??
Old Jun 24, 2009 | 10:14 AM
TooLateVTEC's Avatar
Are you spraying any WD-40,PB Blaster, Fluid Film on it at all?
Old Jun 24, 2009 | 10:19 AM
Well i try everything i know to no effect i goin plan b. I put some 4min jb weld on the end of a socket to the knock sensor let sit for about good hour then ty again.
Old Jun 24, 2009 | 10:13 PM
Notmyvette's Avatar
did the jb welded socket work?
They make like ez-out sockets. like the sockets sears sell to get off stripped or lock lugnuts, they have the spirals on the inside that bite better into it the harder you turn it. I think 22mm is a common size of a car lugnut? if not might be able to buy one of those sockets not sure
Old Jun 25, 2009 | 06:43 PM
XtraCajunSS's Avatar
You may have a serious problem. Those sensors will twist apart pretty easily. You may end up having to drill out the threaded end.
Shane
Old Jun 25, 2009 | 06:49 PM
It didnt work but i got it out by pullin the vally plate off. I got it with a pair of vise grip.
Old Jun 25, 2009 | 09:18 PM
Notmyvette's Avatar
I didn't know the valley plate could come completely off with the knock sensors still in?
Old Jun 26, 2009 | 08:24 AM
01ws6m6conv's Avatar
The sensors are threaded into the block through the valley plate.If he pulled the valley off with the knock sensor in hes got some serious problems. I just had mine off as I installed the ls6 valley cover.
Old Jun 26, 2009 | 09:27 AM
massls1guy's Avatar
Well I've never pulled off the valley cover with a knock sensor still in there. But there are big rubber grommets under the knock sensors (pic from ls1howto.com), it's not metal under them:
Old Jun 26, 2009 | 10:32 AM
It will come out but you will most likely need new knock sensor seals afterward.
Shane
