Which Rocker Arms
Old Jun 25, 2009 | 01:38 AM
SIKSIX's Avatar
Default Which Rocker Arms
What are the best one for the money......
and where can i find the cheapest meizier polished wp?
Old Jun 25, 2009 | 07:38 AM
Old SStroker's Avatar
Originally Posted by SIKSIX
What are the best (rocker arms) for the money......
1. stock GM LS arms
2. stock GM LS arms with bearing and trunnion upgrade
No clue on shiny water pump sources.
"If it don't go...chrome it!"--Stroker McGurk (1950)
"If it don't go...polish it!" --Old SStroker (2009)
Old Jun 25, 2009 | 11:32 AM
SIKSIX's Avatar
How do i go about doing that. Alu. roller rockers ive heard make an extra 15-20 hp. How much power does upgraded stock free up?
Old Jun 25, 2009 | 04:03 PM
XtraCajunSS's Avatar
Stock GM or Stock GM with upgraded trunions.
I can help you with the polished WP as well.
Thanks,
Shane
Old Jun 25, 2009 | 04:19 PM
You have been listening to the wrong people. Actually, using aluminum roller rockers in place of stock LS rockers may cost you power. The are heavier and have more weight over the valve which is bad, and they are not as stiff (they are more "flexible") which is also not good. It takes more spring to control them which is also not good.
Upgrading the bearings on stockers is for increased durability, not for more power. Many, many folks run OEM stockers on high hp high rpm engines without the upgrade. That's why I listed them first.
There is an upside to brightly anodized aluminum roller rockers: they look bitchin' to the ricers when you pop off your rocker covers.
(Sarcasm button now off)
Jon
