Oil Pressure Problems?
Old Jun 27, 2009 | 05:28 PM
antonio84's Avatar
Default Oil Pressure Problems?
About 2 years ago i had my engine rebuilt ever since i got it back my low oil pressure gauge it has been reading low about 20psi at idle and when i would punch it would go as high as 45psi at first i tought nothing about it but yesterday after a few runs my oil pressure gauge was reading a 0psi at idle and would punch it and it would only go 20psi it has a ls6 ported oil pump, i use rp 10w 30 any advice would be good.
Old Jun 28, 2009 | 10:25 PM
antonio84's Avatar
Nobody? well i been drive in it all over the city these past few days and nothing oh quick question where do u connect a manuel autometer oil pressure gauge to?
Old Jun 29, 2009 | 05:38 AM
vsocks1's Avatar
Doesn't sound good to me. 20 psi at idle is low...my engine is typically 35-40 psi at idle. If you went to zero....that is a real problem. I wouldn't drive it until I got it figured out.
Old Jun 29, 2009 | 06:42 AM
05gto60's Avatar
20 at idle isnt bad but its not great either, its the 45 at WOT id be worried about. the spec is about 8PSI per 1000 RPMs.
