Single or double springs for a street car
Old Jun 30, 2009 | 08:36 AM
Intercooler2's Avatar
Default Single or double springs for a street car
I'm ordering heads today but have a couple of questions. The cam I will be using is .580 lift and I just put .600 rated bee-hives on my stock heads. The new heads will have .650 rated double springs which may/may not clear my 1.85 rockers. As an option I can knock off $200 and get the heads without springs... install my bee-hives on the new heads. Would their be any benefit to the higher rated springs given my lift or to the bee-hives maybe being easier on the valvetrain? Just curious also those guys running >.600 lift daily or lots of mileage how you are making out with doubles.
Old Jun 30, 2009 | 09:03 AM
TooLateVTEC's Avatar
I wouldnt use the beehives...they arent rated for enough lift.
Use the doubles that are coming on the heads and keep the beehives as back ups.
Old Jun 30, 2009 | 09:21 AM
.600 rated. Scoggin said not much over .600 when I asked him about them. I'm at .580
http://www.sdpc2000.com/product/SDL1...S1Setof16.aspx
Old Jun 30, 2009 | 09:25 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
You need to factor in the new lift ratio if you have not already. Almost all LS camshafts are rated at 1.7 rocker ratio. if you are using 1.85s and have not compensated with recalculating the lift, then you should do so and then make your decision.
Old Jun 30, 2009 | 09:28 AM
slt200mph's Avatar
Duals are always better than single springs..very seldom do both inner and outer springs break at the same time...keeps a valve from dropping and causing a expensive repair...those dual springs should clear your rockers..the comp 918 spring has had numerous bad batches of springs and I would choose a different beehive spring than the comp 918 if you feel that is what you want...PAC has a good beehive spring..
Old Jun 30, 2009 | 09:34 AM
TRANS-DAD's Avatar
I would worry more about what would happen if you broke a beehive than "will a double spring stress my valvetrain more" there's always a safty factor w/a second sping in place!
Old Jun 30, 2009 | 09:41 AM
Patriot Golds ratings:
Max. Valve Spring Lift: 0.650"
Spring Pressure Closed: 135 lbs. @ 1.800"
Spring Pressure Open: 375 lbs. @ 1.090"
The cam is .537 but with my 1.85's it is .581
Which one John? LOL
Old Jun 30, 2009 | 11:03 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
ideally which ever one you want. if there is one you feel more comfortable with. even with a longer lever....it is really still up in the air.
Old Jun 30, 2009 | 12:44 PM
02*C5's Avatar
If your total lift is .581 and your spring is rated to .650 I think that there should not be an issue at all. The patriot Gold are excellent springs use them myself. my cam is rated 600/600
Old Jun 30, 2009 | 01:08 PM
Well I went ahead and just had them put on the duals. A bit much for me but if it is a little safety net then I'm okay with it.
Old Jun 30, 2009 | 01:41 PM
allngn_c5's Avatar
The dual spring setup should last a long time on the .581 lift. Less maintenance just install and forget them. I bet you'll still be running the same dual springs 5 years from now without a care in the world. Good luck.
Old Jun 30, 2009 | 02:31 PM
slt200mph's Avatar
The cam I run has .581/.588 lift and I change the dual springs every45,000 to 50,000 miles ... no problems I am on my 4th set of springs at this time.
Old Jun 30, 2009 | 03:02 PM
allngn_c5's Avatar
So how many miles on your car so far ?? 150K +
Just left Georgia bro. I loved my stay down there. So much in fact I could see myself retiring there in 15-18 years.
Old Jun 30, 2009 | 03:37 PM
WeathermanShawn's Avatar
No hijack attempt here, but are there any inherent advantages to keeping a good quality single beehive spring over a dual?
I.E., will a single beehive spring allow a higher rev (valvetrain weight) over a dual? Not to be a lightweight here, but are dual springs noisier than singles?
OP, hope you do not mind the additional clarification and question added.
Thanks.
..WeathermanShawn..
Old Jun 30, 2009 | 04:07 PM
david vericker's Avatar
The Beehive designed spring combined with the Ti retainers will provide more valvetrain stability due to the overall weight factor,thus allowing for quicker revs and a higher rpm capability.At 581 lift the best bang for the buck and overall performance is the beehive springs hands down, and don't tell me otherwise...this is based on experience with this very cam!!!
Old Jun 30, 2009 | 04:49 PM
Thimble's Avatar
Typical lobe lift of a cam is in the .300-.380" ballpark.
It seems you are basing this on the "advertised lift" which assumes 1.7 rockers will be used.
With 1.85 ratio rockers, you are now looking at .631" actual lift.
Only beehives I know of that will handle that would be the PAC 1518s.
Old Jun 30, 2009 | 05:15 PM
No this is .534 valve lift with 1.7. Cam is XR277HR
Old Jul 1, 2009 | 12:47 AM
slt200mph's Avatar
It just clicked 190,000 miles on last Saturday moring... the engine uses a 1/2 quart of oil every 5,000 miles and sees the red line every day of its life...
Old Jul 1, 2009 | 07:25 AM
allngn_c5's Avatar
That is just amazing man !!!
Old Jul 1, 2009 | 10:35 AM
Frans96SS's Avatar
Good choice in the duals.
