Ms3 cam users need info
Old Jul 4, 2009 | 05:26 PM
diablo-Z's Avatar
Lightbulb Ms3 cam users need info
got a question is anyone running that cam package from texas-speed a ms3 cam with the afr 205cc heads how's that combo what do yall think?? or should i go with a diff heads on the ms3 cam....whats heads do yall use with the ms3 cam. feedback will be helpful.. Thanks Guys Eric
Old Jul 4, 2009 | 05:47 PM
black01_WS6's Avatar
You can go wrong with AFR heads. the MS3 cam will work great with those heads on stock cubes.
Old Jul 4, 2009 | 06:25 PM
diablo-Z's Avatar
so those heads with flow perfect with the ms3 cam
Old Jul 4, 2009 | 07:12 PM
khenry's Avatar
I have TSP stage 2.5 5.3L heads / MS3 cam combo makes 439 RWHP. with 42lb injectors/255 pump
Old Jul 4, 2009 | 07:43 PM
diablo-Z's Avatar
is ur car auto or stick.........
im gna get a fuel pump first then install the cam cause my fuel pump is preety week
Old Jul 4, 2009 | 11:44 PM
khenry's Avatar
stick
Old Jul 4, 2009 | 11:49 PM
Coonass350's Avatar
not to hijack your thread but..what kinda valvesprings do you guys run with the MS3 cam?
Old Jul 4, 2009 | 11:54 PM
mchdg86's Avatar
The cam Patrick G used in his 500 rwhp combo was pretty much an MS3 clone. But he had every single bolt-on and a perfect tune to get there.
Old Jul 5, 2009 | 12:37 AM
diablo-Z's Avatar
i was talking to trever on texas-speed awhile back he said for me to go with the torquer v3 with the 5.3L stage 2.5 heads but i like the ms3 better read alot of good things about this cam makes more power too
Old Jul 6, 2009 | 12:21 AM
diablo-Z's Avatar
does anyone have that set-up ms3 cam and afr 205cc heads..dyno numbers,track slips or something just want to know how that set up will be
Old Jul 6, 2009 | 10:39 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
If you would like I can provide you with engine dyno data from several different cylinder heads with that camshaft. For the money I honestly think you'd be crazy not to look to the PRC 215 heads, or a set of TFS 215 heads. The reason I think you'd probably like the PRC 215s best is because the better p/v will allow you to run a smaller chamber while still clearing the MS3. The TFS head will probably only allow you about 64cc chambers with the MS3, while the PRC heads can get you 59.5cc chambers!
If you'd like we to come down we can spend a little time on our engine dyno & I can show you the power advantages these heads provide over the afr 205 heads.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 6, 2009 | 02:20 PM
diablo-Z's Avatar
yeah if u can do that show me dyno diff on the heads that would be helpful thanks
Old Jul 7, 2009 | 07:53 PM
diablo-Z's Avatar
ttt...
