Oil pressure problem, or loose nut behind the wheel???
Have a 99 Z28 with 51K on the clock....take a peek at the photos below..this is hot idle psi. All internals are 100% bone stock, any mods are in the sig....
There is no wild swings in pressure, and when you hammer it the pressure jumps up to 40 plus psi.
Is this a sign of trouble, or am I making an issue out of nothing?
Outside of the milage, my car does the exact same thing....cold psi @ idle is 40psi...once it hits 210 then it drops to 20.
The only reason I even ask is because my 02' Avalance has 40 psi @ idle hot...
The only reason I even ask is because my 02' Avalance has 40 A @ idle hot...
Also does anyone know where i can get one. I'm going to do that when i put my ls6 intake on.
so you can replace the sensor pretty easily with this special socket from autozone?
might have to do this!
