Stripped lifter tray bolt Question
DOUGH!!! Why me?!?!
So when I pulled the bolt out, about half the threads came with it. I tapped the hole out with the standard 6mmx100 thread but I just wasn’t comfortable with the way it felt.
I JB welded it and let is sit for 2 days to fully cure and tapped out a new hole. I put a ton of Red thread lock on it and torqued it to 60 in lbs. It felt tight, the lifter tray was totally secure, but I was afraid to tighten it to 106 in lbs and push my luck.
I re assembled the engine, and it runs, but my sphincter is a little tight about the repair job on the lifter tray. The bolt doesn’t really bare any pressure short of keeping the tray and lifters in place, but if it were to fail and the lifters moved off the cam it could get messy.I do plan on using the car for HPDE Road race style of driving. In retrospect, I would have gone to a 7mm bolt and re threaded the aluminum and come up with a way to keep the tray in correct alignment with a little brass washer/spacer or something.
Should I take the head back off and do the 7mm bolt fix or since the tray doesnt see load will the jb weld and red thread lock suffice?
