Symptoms of cam being off a tooth?
But at the same time I really don't know if it even could be. The car is down on power for sure, but the weird thing is extremely rarely it seems to run better (like 3-5 times since the engine was installed nearly a year ago). The transmission acts like trash and short shifts most of the time, but once in a blue moon the car feels amazing and the transmission firms up and starts shifting where it should. This made me think MAF sensor problem....but a borrowed one from a friend did no better.
Put in 3 different tunes with no results. No codes, my sensor readings look normal best I can tell, plugs/wires are perfect, no knock retard, good timing, good pcm grounds...
I am just at a loss. I'm frustrated to the point I hate my car.
On the dyno it made 325rwhp with cutouts open (so please don't point fingers at the exhaust) with the ls1 intake. Now I am trapping 86-87 in the 1/8th
and getting outrun by bolt on cars. I estimate my rwhp to be around 340-350 max right now.I really think the issue is something electrical but I'm out of things I can check and getting desperate.
On the dyno my power peaked and fell off at 5600rpm, everyone told me it was the ls1 intakes fault so I got rid of it, I can tell I have more power up top for sure but I've been reading and searching on here the last 2 hours and several people say the cam being off a tooth would cause the early peak and drop off instead of peaking later and riding out some.
The drivetrain is a little louder than I expected it to be but I'm not used to ls1s so I don't know how normal some noise is for a cammed car. It got a lot louder when I put the fast intake on.
I almost want to just run the thing off a cliff.
maf sensor
map sensor
tps sensor
all pcm grounds good
plugs
wires
coil packs
o2 sensors fluctuate normally
vss sensor reads correct
voltage is 13 running
cylinder balance test didn't show a weak cylinder
26 degrees timing WOT
knock sensors replaced during intake swap, no knock retard
no vacuum leaks or leak symptoms at idle
no misfires according to scans or noticeable to me
I am out of ideas...I might have even missed listing something else I tried
what range should they be in? I'm really leaning to this being some kinda of electrical issue, most likely MAF related
I am really leaning toward it being some kind of electrical thing still, every once in a blue moon the car will come alive...this includes firmer shifts and proper wot shift points. 99.8% of the time the pcm short shifts by several hundred rpm to as much as 500rpm for no apparent reason.
Not only is the trap low but a friend's bolt on trans am missed third and still beat me by a car in a roll race from 50-120 while he weighed more than me.
I know the stall sucks but something else is amiss I'm pretty sure.
whenever its running better and the trans is working right its something you can even hear in the idle...it sounds a lot meaner like a cammed ls1 should, very aggressive idle with lots of the pop one would expect from a higher compression engine
i checked my pcm ground but just realized i don't have a ground from the engine to the chassis, just the negative battery terminal is grounded to the block and has a small lead going to the fender
is a engine to chassis ground necessary?
I meant I didn't know if there needs to be a wire going from the block to the car body/frame also.
I'm starting to wonder if there might be an issue in the harness or pcm itself.
Yes, there are two grounds going from the sides of the block near the bottom to the frame. Since the PCM is grounded to the block, the block needs to be grounded to the chassis.
The reason I though of it is I had a weird problem where the battery cable turned out where its bolted to the head a couple weeks ago because the bolt loosened up...and there was an arc jumping from the cable to the header flange during starting. Seemed weird to me, but I just cleaned the terminal end, turned it back down where it only touched the head and retightened it.
When he first got the car it was very strong but spun a rod bearing within the first 500 miles. The guy he bought the engine from was kind enough to rebuild it free of charge. Every internal engine component is original with the exception of the crank and one connecting rod, which were taken from a 5.3 engine the seller had for parts. Compression is great along with all sensor signals and outputs. My next step is going to be to pull the engine to inspect the reluctor wheel on the crank. I pray that I find a damaged tooth on it because if that's not the problem I have no idea where to go from there.
I am not attempting to hijack your thread, just sharing my experience with what sounds like a very similar problem in the hopes that one of us will find the culprit. Good luck with yours and if I find anything I'll be sure to post it here.
