Shaving Stock LS6 Heads -Power Gain?
Since I'm a new father as of this weekend, the budget to buy ported heads isn't in the cards, however I'm adding a medium cam, polished stainless headers, and a polished/clearcoated powerbond pulley. I'm putting another polished Lingenfelter intake on to help make everything look like a chrome overload.
I was thinking about having the heads shaved maybe 20 thousands and having a valve job done.... since the heads would be off anyway. I know I'll need shorter pushrods.
Does anyone have advice on how much to mill, etc?
Thanks
The valve job is where you'll get most of the benefit, but yes decking them with a cam will yield more power. I do this all the time on stock 243/cam swaps in the F-bodies or GTO's.
You need to try the cam I use. Works with LS6 heads shaved .015, and makes 420-430rwhp with an unported 243. Driveability is perfect.
Damian, can you pm about your cam specs? I'll keep you in the $middle$ as long as the LSA is 113ish I'm happy. I don't want the typical 111 LSA sound, not that it's bad... I just want a "burble" at idle, not a "chop" on this car.
You should see a easy 25hp gain with no compression bump even with stock valves. We've seen 45hp with milling & stock valves!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Serious customers call to settle details, not yap.. But it will be two months before a tear everything down. I'll call then.
I do have two questions that may help others who'd like to know.
1) What is the typical turn around time?
2) Is the work done on my actual castings, or are they traded as cores?
For price and perfomance your heads are tough to beat
Who is doing the work? I need some work done on my ls6 hheads.please get ahold of me.
