Swapping in flat top pistons into an LQ4
Can I simply swap the LQ4 pistons for as set out of an LQ9? I understand that the 2005 LQ4 got better rods, though I'm not positive they're the same as the LQ9.
I'm already past my budget, but if this would work, it'd be a pretty good way to raise my compression without milling the heads.
A word of advise - milling the heads should only cost $100, vs. a bunch more, unless you're going with used pistons.
I also have seen used LQ9 pistons go pretty cheap in the sale section.
