Texas Speed 220R Engine Dyno Data!!
Old Jul 21, 2009 | 10:59 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Possibly in time dug, this is also a lot of data for TSP to sift through also, last I checked it was at pull # 130!
This is my personal engine on the dyno right now and I've been degreeing in the each of the cams tested (in-between installs). I'm at 45 minutes for a swap and degreeing currently! Too easy.
Old Jul 21, 2009 | 11:05 PM
dug's Avatar
dug
Have you done any dyno testing with the truck intakes? not that theyre better but thats what the trucks run.
Old Jul 21, 2009 | 11:19 PM
Gordon0652's Avatar
Jon & Matt,
Looks like you have a nice toy to play with... AWESOME! Keep up the excellent work & service!
Old Jul 21, 2009 | 11:26 PM
-Joseph-'s Avatar
Dug, no plans for the truck intake, but if I locate one, I'd be interested in testing it.
Old Jul 21, 2009 | 11:45 PM
Black98Z28's Avatar
Looks like you guys have expanded a little bit since I was down there!
TSP knows their stuff!
Old Jul 22, 2009 | 04:25 AM
dug's Avatar
dug
thats cool. You know one dyno I would be interested in is open headers vs open ypipe
I wish I had an engine dyno, it would be so much fun testing different combos.
Old Jul 22, 2009 | 07:31 AM
briannutter's Avatar
I think this is great and support you not passing out the advance numbers. All that happens then is a bunch of post monkey's regurgitating your hard earned work as their own knowledge.
Old Jul 22, 2009 | 08:22 AM
Felix C's Avatar
Do not wish to hijack the thread but is there a sleeper cam in the works?
Old Jul 22, 2009 | 08:29 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Thanks guys for all the support. Sorry we can show everything we learn on this deal, but I promise we're using all the data we can to produce the best possible TSP products!!
Thanks for all the guys pm'ing me in the background! We appreciate the support!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 22, 2009 | 08:31 AM
Originally Posted by Patrick G
I would tend to agree. By advancing the cam, you would have picked up nicely in the low and mid-range, but sacrificed the top-end power. For guys who want to shift at 6400 rpm, this may be a sound move.
Like I said in the other post this camshaft was +4 for a 108 ICL. This is exactly the reason we do the testing. Theories only go so far, the dyno confirms or busts theories..
__________________
Jason
2005 Twin Turbo C6
Old Jul 22, 2009 | 08:47 AM
Just for this camshaft here's the +2,+4,+6 Data. I thought I had data from 1-5 Advance, but on the 220 cam I only did 2,3,4 & 6.
Here's 3 of them just to keep the graph clutter free...
__________________
Jason
2005 Twin Turbo C6
Old Jul 22, 2009 | 08:52 AM
  #32
ls1-14 in blue has the best area under the curve. Which advance is that one?
Old Jul 22, 2009 | 08:56 AM
  #33
22 is +2
14 is +4
16 is +6
__________________
Jason
2005 Twin Turbo C6
Old Jul 22, 2009 | 09:14 AM
  #34
I should really be working on pistons right now, but I'm considering this as research into our valve pocket depths.
I overlayed the curve of the 220 with the 224/227. from 4700 to 6500 it's a bit more than 10 to 15hp higher through the range.
Looking at the torque from 2000 to 4000-the numbers are very similar.
Can you guys post idle vacuum numbers for the two cams? Would an average guy notice the difference in the idle?
Old Jul 22, 2009 | 09:35 AM
  #35
Nutter shouldn't you be working??? Besides I need a set of 440 LS7 pistons for my personal 2010 Camaro! I'm calling you later today!!
__________________
Jason
2005 Twin Turbo C6
Old Jul 22, 2009 | 01:28 PM
  #36
dug's Avatar
dug
thnax for posting the graph TSP appreciate it.
Old Jul 22, 2009 | 05:28 PM
  #37
GT Griller's Avatar
Cool..great results!!
